Old 10-05-2001, 06:24 AM   #136
The 414M is not leagal for TCS races which are Tamiya only, you however can race the car in most local club races, or Roar/Ifmar races.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 10-05-2001, 08:10 AM   #137
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The last I heard was because it wasn't a production run car (whatever that means) if you attend a ROAR national event you would have to run in Modified. I think the same problem happened to the 414X car. Maybe because they were a limited production run. Somebody correct me if I am wrong but on a club level they are fine.
Kraig is offline   Reply With Quote
Old 10-05-2001, 09:25 AM   #138
At a ROAR event you can run stock or mod. ROAR has nothing to do with Tamiya. TCS races, the 414M is not legal. At ROAR sanctioned races it's just another 4WD touring car; run what ever class you want. Although the car might be under weight.
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 10-05-2001, 10:46 AM   #139
Super Moderator
Kraig's Avatar
See, I stand corrected.
Old 10-06-2001, 01:28 PM   #140
jcr
Exclamation Pinion gear
ok just got the TA04R all built and was wondering what gear ratio should i have for the P2K. Also can you use 64pitch pinion with the 0.4module spur??
jcr is offline   Reply With Quote
Old 10-06-2001, 01:46 PM   #141
Aurra Sing's Avatar
I was recommended a 120/38-40 gearing for the stock motor. The TA04R includes the 120t already, so you just need the pinions.
Aurra Sing is offline   Reply With Quote
Old 10-06-2001, 07:16 PM   #142
jcr
ya but Tamiya pinions are more expensive that the other brands so can you use 64pitch pinion?
Old 10-06-2001, 07:51 PM   #143
Aurra Sing's Avatar
Yes, you can use other brand 64pitch pinions. I used to use RRP pinions, but I never liked them because the grub screw strips too easily (not to mention you need an exact 1.5mm Hex Driver, such as the MIP one, the L Shaped driver the kit supplies you with won't work well with RRP Pinions.) I now use Tamiya ones.
Old 10-06-2001, 07:56 PM   #144
jcr
so the mesh is the same?
Old 10-06-2001, 08:50 PM   #145
Alvin's Avatar
Another thread mentioned using HPI Pinions. OTOH I use Kawada 64p duraluminum pinions. Works great. But I put loctite on my grub screw so it next to never comes out...
Alvin is offline   Reply With Quote
Old 10-06-2001, 08:55 PM   #146
jcr
guess 64pitch will work. might get the 64pitch if it's a lot cheaper. and other brands of pinion is TCS legal right?
Old 10-06-2001, 11:12 PM   #147
TFR
TFR's Avatar
it won't be that much of a difference, will it?
just get the Tamiya stuff
TFR is offline   Reply With Quote
Old 10-07-2001, 05:52 AM   #148
Alvin's Avatar
Default High Torque or High Rev?
Found a *bit* more info on the Type T & Rs, as well as prices. Both seem to be priced the same @ 2,600yen. According to this URL
http://www.tamiya.dk/rc/ta04_hopup.html
Type T
Type R
The Type T is meant for high torque usage, whereas the Type R is for high revolution (high speed?) usage. What's preferably for a technical circuit?
Old 10-07-2001, 07:05 AM   #149
jcr
TFR the pinions might not be a lot. $21 for Tamiya (a pair) and $6-8 for others so it'll be $12-16 but if it's $6 for a pinion then i'll get those one.
for technical track get the Type T. just like other stock motor, technical is P2K on wide open traks are Type R same thing like the GM3
Old 10-07-2001, 08:25 AM   #150
TFR
TFR's Avatar
OH...
TITC 2006 - Woohoo! :D Kenneth Tan Singapore R/C Racers 13 02-23-2006 07:48 AM
TA04R for sale sdd6131 R/C Items: For Sale/Trade 5 01-11-2005 06:12 PM
Tamiya Ta04r superk R/C Items: For Sale/Trade 0 08-15-2003 10:09 AM
TA04R minicooper R/C Items: For Sale/Trade 4 06-24-2003 04:53 PM
ta04r f/s drool monkey R/C Items: For Sale/Trade 3 05-27-2002 08:39 AM
