connection on receiver
hi guys..i need a little help here.
my receiver is a Futaba R122JE and the channel 2 connection is on the top, followed by channel 1 and the battery connection. should my servo plug go into channel 1 or channel 2?
so after i plug the servo into channel 1, if the wires are red, black, white(left to right)..then for the ESC, i have to plug them according at channel 2 - wires being red, black and white(left to right) also?
cause for my esc, the wires were red, white, black...then for my servo, was red, black, white..so i have to change the wires on the esc to red, black, white, making it the same as the servo..
my servo is a KO Propo PS401. receiver is a Futaba R122JE. esc is a Sanwa F-12B....
i had switched the wires on the esc to follow the wire pattern of the servo..cause according to the salesperson, the servo(channel 1) is the MAIN plug, so the esc being channel 2 would have to follow the wire pattern, if not my esc would burn..that's what she told me
anyway.. thanks alot Matt! really appreaciate your help!
