Old 06-24-2011, 08:03 PM   #1
Default Tamiya TT-01 Suggestions
I'm on a 500$ budget. I'm gonna Purchase a Tamiya TT-01 Sometime in November, which leaves me tons fo time to learn. I do know that My Car, the Battery and everything I need cost 306USD in-all (Plus Shipping). Thats leaves around 100-200$ left to customize my TT-01. Now heres where you guys come in .
I plan on creating a RC Club, Driving around with friends (All four of them are planning on purchasing a TT-01 Too; in July and August), racing @ events and drifting. I'm already gonna get Racing Tires for Non-Drift Racing. Other than that... I'm stuck. Please Help
BTW, I wanted to paint my Body and add an RC exhaust but sadly, I'm a terrible Painter so I wouldn't know how that would work.
Wavey_King is offline   Reply With Quote
Old 06-25-2011, 09:19 AM   #2
mytto1's Avatar
Alright yer gonna need the aluminum drive shaft, stock is gonna flex and rattle (around 12-15$)
Bearings, the stock bushings/bearings just plain out suck (20-25$)
New dampners, depending where you get it the prices will vary, in the hobby stores they are normally 70$+ but i order mine on rcmart.com which i can get some for 35$ thats with shipping and handling.
Aluminum steering links are good too, stock are fine but in my opinion the aluminum with bearings handle smoother. in stores 60$+ and once again rc mart has ehm for CHEAP.
from my experiences with the tto1 thats bout all is really needed but i still went all out with mine
mytto1 is offline   Reply With Quote
Old 06-25-2011, 12:42 PM   #3
cartix's Avatar
Trader Rating: 33 (100%+)
This thread has all your TT01 answers.
TT-01 Forum
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 06-25-2011, 02:15 PM   #4
MrUnlimited's Avatar
Bearings, hard driveshaft and brushless set!
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 06-25-2011, 07:06 PM   #5
Trader Rating: 27 (100%+)
Your first mistake is buying a TT01.
B5 | B5M | TC6.2
Hobbywing | Savox | Airtronics
RC.Jon22 is offline   Reply With Quote
Old 06-25-2011, 07:35 PM   #6
Ty for those who helped,
@RC.Jon22 A little too mean/aggressive?
Old 09-01-2014, 11:42 AM   #7
Hi guys im a noob but could you tell me if this motor and esc would be fit for drifting with a locked diff and ball bearings , with a aluminium shaft , or do i need a higher turn motor lik 13.5 turn , Thanks
TitanRS is offline   Reply With Quote
Old 09-01-2014, 04:55 PM   #8
better off with club tc4
TeamThibault is offline   Reply With Quote
Old 09-01-2014, 05:05 PM   #9
longuylander's Avatar
Are you starting with a TT01E kit? If so, the drive shaft and bearingsare definite necessities. If the kit already comes with oil shocks, aluminum ones aren't necessary, but RCMart has 3racing ones for the TT01 for cheap. Same goes for bearing steering. And yes, I'd definitely hit RCMart first for the other stuff too; some things (like the steering) are free shipping. I'd also suggest the 58/55 tooth spur gears and larger pinions. The TT01 uses Tamiya's AV size, and can be bought in pairs of 20/21, 22/23, and 24/25 teeth. You may eventually want cvd axles, but be careful there, as some of the aftermarket ones need you to buy different differentials as well. Again, RCMart has some great ones: solid axles, ball differentials, and one-way differentials.
longuylander is offline   Reply With Quote
Old 09-01-2014, 08:50 PM   #10
ThePanda's Avatar
Trader Rating: 64 (100%+)
Why not look at a better car to start? The tb03 is shaft drive, comes with aluminum shaft, bearings, machine screws, and aluminum adjustable motor mount standard. Not to mention tunable diffs, metal dog bones and full metal axles. Plus oil shocks, camber and caster changes, kick up, and roll center adjustments.
All those are just things you would spend to change out on a tt01 anyways, and stil end up with an inferior car.
ThePanda is offline   Reply With Quote
Old 09-01-2014, 08:52 PM   #11
ThePanda's Avatar
A 13.5 is just about perfect for all around drift action.
Old 09-03-2014, 01:13 AM   #12
That is the best advice here.
If you MUST get a TT01, dont spend $$ on it, its money down the drain.
Only buy ball bearings & metal drive shaft. Why they never came with these most basic of parts is beyond me.
Plastic dogbones...really ???
The TT01 is a very crude car. If it was made by any other brand it would be considered a joke, considering its price.
Buy a TB03 or TB04 instead. Or a Sakura .
Ive owned 2 TT01's . they are what they are. Extremley crude , but bulletproof. And alot of fun admittedly.
1101 is offline   Reply With Quote
Old 09-03-2014, 02:21 PM   #13
If you and four of your friends are all going to get TT01s, then it doesn't matter that it isn't the best chassis. You can have a blast driving with them, learning the nuances of car control, and slowly upgrade your car as you improve. When you're all ready to move on, you can all get better cars and have fun again.
Old 09-03-2014, 02:57 PM   #14
ThePanda's Avatar
The plus to the tt01 is that it comes with a body, esc, and motor. So you could get the kit and spend 55 dollars more for radio, servo, and battery/trickle charger and have a running car. Assuming you have someone to paint the body, or that's another 7-15 dollars. So having a rtr car for under 200 is pretty good.
Old 12-08-2014, 11:38 PM   #15
We have a heat just for the Tamiya TT-01's at our club and it has on occasion been two heats. It is about having some fun whilst racing, with a few youngsters learning too, some have pick-ups bodies on their cars and most run tyres out of the club's used tyre box (so mostly used Sorex 32's). Granted they aren't the most complex and but they are quite robust - they need to be given the paint-trading that goes on between some of them. Below is the rules that they run to.
Tamiya TT-01 Cup
Rules
- Chassis must be a TT-01 or TT-01E kit by Tamiya.
- No adjustable parts to be used i.e turnbuckles, toe in parts.
- No oil filled shocks to be used, only kit friction shocks.
- Stock Silver can motor by Tamiya to be used as per kit, NO G2 cans.
- Gearing is open which is 0.6 mod pitch, Tamiya only spur gears by pinions are open to other manufacturers.
- Nimh batteries 7.2v only to be used with any connectors, no lipos.
- Tyres are open.
- No additive or tyre warmers to be used.
- No motor fans or heatsinks.
Bodyshells
- Any Real/Scale Bodyshell in 190mm or 200mm can be used
- No touring car shells to be used which are made for performance racing i.e the touring car class, some examples are Protoform mazde speed 6, ltc-r, p-37. Blitz tsx, isf, gsx.
- Please ask on the group page if you are unsure about a bodyshell before purchasing
it
- Wings to be more scale then performance, No metal wings allowed due to safety
Upgrades
- Ally center shaft and ally wheel hexs are allowed as over the testing period these have proven to be the 2 main weaknesses but are not necessary.
- Full ball bearing kit is permitted
Lantern Rouge is offline   Reply With Quote
Tamiya TT-01 XB Wavey_King Electric On-Road 14 06-25-2011 07:41 PM
newbie- need car: tt-01, 19T, 2S lipo? iamscottym Electric On-Road 9 07-18-2006 10:39 PM
How to make your Tamiya TT-01 Go Faster? RedEnzo Malaysian R/C Racers 66 06-01-2006 02:45 AM
Tags
rtr, suggestions, tamiya, tt-01
