Old 10-11-2004, 06:43 PM   #1
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Default 64 pitch gears
I was just wondering what are the advantages of 64p gears.
I'm intersted in installing them in my tc3, soon to be a tc4. Also, what should be a general gearing for a 19t.
Paul_TC4 is offline   Reply With Quote
Old 10-11-2004, 07:13 PM   #2
Charlie O's Avatar
one advantage is that you have finer gearing options, the mesh is finer, so say using a 25 tooth 48 pitch compared to a 64 pitch 25 tooth if you went up one tooth on the 64 pitch it is like going up 1/2 tooth on a 48 pitch hope i explained that ok, on e disadvantage is they strip easier, & you pick up debries more so if you run parking lots stick with the 48 pitch!
Charlie O is offline   Reply With Quote
Old 10-11-2004, 07:17 PM   #3
josh69162's Avatar
Send a message via AIM to josh69162
The mesh is finer, but in terms of debris, I have never ever had a problem with it. I've had more dirt get in my motor than in my gears. But I guess it all depends on where you run.
josh69162 is offline   Reply With Quote
48 and 64 pitch gears yeahyeah Electric On-Road 8 06-13-2008 08:37 PM
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 06:08 AM
BK Pitch gears RayB R/C Items: Wanted to Buy 0 07-01-2007 10:09 PM
want 64 pitch gears Ultraspeed84 R/C Items: Wanted to Buy 5 04-02-2006 01:58 PM
64 pitch gears brettb76 Rookie Zone 10 11-24-2005 08:04 PM
SEO by vBSEO 3.5.0
