Old 02-24-2017, 03:25 PM   #766
gigaplex's Avatar
Originally Posted by kenshirogenjuro View Post
I wonder if this was only an early product run issue or did it go the entire time without anyone figuring it out?
I just got a Mach 3 and wonder if I'll have to make a similar "adjustment". Timing should be timing...I shouldn't have to compensate for a manufacturer building-in an error.
I suspect it has been that way the whole time, judging by all the comments I read that the motor runs way hotter than the previous model at the same timing.
gigaplex is offline   Reply With Quote
Old 02-25-2017, 05:38 PM   #767
Trader Rating: 44 (100%+)
Starting point for timing?
3.5 Mach 2 1s Blinky 1/12th scale ~40mm roll out
biz77 is offline   Reply With Quote
Old 02-27-2017, 09:54 AM   #768
Send a message via AIM to GuyIsDamGood
I have a Sonic 6.5(from 2009 - 2010) it came set with 0 timing. That motor never gets hot.(5 - minute runs/races and geared right)
I also have a Sonic 10.5 Mach 3. It came set with 20 timing. It gets warmer quicker than the older 6.5.(5 - minute runs/races. . .geared right...?)
I'm going to set the 10.5 Mach 3 timing to 0.
It should run cooler. . .and cheaper(I wouldn't have to buy a new motor).
GuyIsDamGood is offline   Reply With Quote
Old 03-21-2017, 10:25 AM   #769
Default 10.5 Sonic M3 kv #s?
Anyone know the kv #s on/for the Reedy 10.5 Sonic M3 motor?
I think I can check the kv rating on my Graupner Polaron EX 1400. . .?
But; I wanna know the #'s from you pros.
Thank You
