Old 12-06-2016, 05:05 AM   #751
I am thinking of getting the 12.5 rotor for my 21.5 mach2 and 17.5 1s mach3 for more torque
I see there is a 13mm; should I get that instead? or is that now not roar legal or maybe overkill.
Or perhaps I should be a whole new high tourque motor?
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 12-06-2016, 05:09 AM   #752
I believe 12.5 is the highest you can go and be roar legal. I run the 12.5 rotor in my 17.5 1s Mach3 in Touring car
Rhett McNair is offline   Reply With Quote
Old 12-06-2016, 01:31 PM   #753
Default Reedy 13.5 timing
Hello,Looking for timing and gearing help with a 13.5 m3 in 1/12 scale blinky,As of now its timed at 38.5 and geared with 48p and a 80spur,motor comes off around 140 after 8mins ,its pulls about 5.8 amps on the motor tester.Motor feels lazy in the in filed but its pretty fst on the straight.Any help with this turd will be great.Rotor is a 272 and its a 1 s version motor.
X marksthespot is offline   Reply With Quote
Old 12-06-2016, 02:00 PM   #754
rc pete's Avatar
You didn't mention what your rear tire size was.
I found the sweet spot for this setup is a rollout of 82-83 mm and then timing till it gets to about 150 after the race. If it's fast in the first 2 minutes and then fades badly in the last 3 or 4 minutes then take the timing down.
Another option is to run the 2s motor with the 272 rotor. That combo has a little more bottom end for tighter layouts and can handle more timing with the same rollout without fading.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 12-06-2016, 08:23 PM   #755
Default Big Thanks
Roll out is around 79-80 now ,will drop the timing and gear it up a few teeth and she wat its does.Thanks again
Old 12-27-2016, 12:54 PM   #756
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Anyone have a good starting point for 10.5 1s boosted rollout for WGT with close to a full size rear tire?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 12-28-2016, 12:52 AM   #757
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Looking for gearing and timing help for 25.5 motor in a F1 car . The track has a 140' straight flowing track.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 01-04-2017, 08:19 PM   #758
Trader Rating: 19 (100%+)
Are ceramics available for the Mach 3 yet?
Coke in a can is offline   Reply With Quote
Old 01-05-2017, 05:10 AM   #759
Avid has ceramics available
http://avidrc.com/product/1/bearings...-bearings.html
Old 01-07-2017, 05:52 AM   #760
Send a message via AIM to GuyIsDamGood
Default It came with 20° Timing
I just purchased the Reedy Sonic 10.5 Motor. It came set at 20° timing. My older Reedy Sonic 6.5 Motor came set with 0° timing.
Should the 10.5 Motor come set at 20°?
Thank You
GuyIsDamGood is offline   Reply With Quote
Old 01-09-2017, 03:53 PM   #761
AE-Reedy
Thank You
All Reedy motors come preset at 20.
Sean Cochran is online now   Reply With Quote
Old 01-11-2017, 07:43 AM   #762
That's true. (the newer motors come with 20° timing) I looked it up. Thanks for the info.
Old 02-04-2017, 02:44 AM   #763
gigaplex's Avatar
Just tested my Mach 2 on an analyser. 34 endbell timing was 46 on the analyser. No wonder it got hot when people kept telling me to crank it over 40.
gigaplex is offline   Reply With Quote
Old 02-04-2017, 03:47 AM   #764
I have the 10.5 motor. It will get a little bit warm when I run the motor on the pit-stand. Is it because of the 20° timing?
Old 02-24-2017, 10:45 AM   #765
I wonder if this was only an early product run issue or did it go the entire time without anyone figuring it out?
I just got a Mach 3 and wonder if I'll have to make a similar "adjustment". Timing should be timing...I shouldn't have to compensate for a manufacturer building-in an error.
kenshirogenjuro is offline   Reply With Quote
