Old 02-23-2015, 05:53 PM   #736
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by stubaxle View Post
I have a Reedy Sonic Mach 2 8.5 which i was running in 2wd buggy, was running great and didn't get over 125 F. Hasn't done that much work but it started cogogging, tried other sensor cables, didn't fix, so tried another motor and everything else is fine.
I assume this could be a sensor board issue, so looked for a replacement on rc10.com, couldn't find one....
Does anyone know where I might get one?
Thanks!
AMain Hobbies have them in stock
http://www.amain.com/reedy-sonic-mac...earing/p253648
Burlap is offline   Reply With Quote
Old 05-03-2015, 08:26 PM   #737
gavaust's Avatar
Trader Rating: 22 (100%+)
Default Reedy sonic 17.5 gear suggestions
Hi guys just picked up the Reedy sonic 17.5 and are running in blinky running in a team c tc02c 2.6 ratio and are looking for gearing suggestions we run on med to large outdoor clay tracks was running 72/32 timing stock and got smashed down the straight any suggestions would be great cheers
Xray xb4 2016
Proamps servo & shortys
Dualsky motor
Hobbywing xr10 pro
Awesomatix a800x
gavaust is offline   Reply With Quote
Old 05-12-2015, 03:53 AM   #738
Default bearing size
Please, what are the sizes of the 2 bearings of Sonic 2 Mod ?
Thank a lot
Fred
fredB is offline   Reply With Quote
Old 06-13-2015, 06:36 AM   #739
pphaneuf's Avatar
Any rollout suggestions for a Mach 2 10.5T boosted 1S WGT?
Also, what timing on the can? How much timing advance for boost and top speed ("turbo")?
pphaneuf is offline   Reply With Quote
Old 06-13-2015, 07:55 PM   #740
Trader Rating: 81 (100%+)
Does the mach 2 21.5 come with a 12.5mm rotor or a 12.3?
dpcardoza is offline   Reply With Quote
Old 10-26-2015, 05:08 AM   #741
Just got my first Sonic Mach 2 (the M3 isnt available in Germany) and I noticed a "strange" "clack" noise every time I psuh the car (so the the motor spins). Sounds like the clack appears every time the rotor hops another step.
Anyone know what I mean and what I hear?
man1ac is offline   Reply With Quote
Old 10-26-2015, 05:14 AM   #742
Trader Rating: 40 (100%+)
Yes..... all motors do that to a point. the stronger the pull between the magnets and the coils produce a kind of snap to the next coil as the magnet turns due to the residual magnetism in the coil. Check your gear mesh and if it's too loose it can make this noise louder.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-21-2016, 08:05 AM   #743
Can anyone help? Wanted to clean it, cause I bought it used. Everything went apart really well, but now I dont know how to get things back in one peace? the 3 parts on the left seem pretty clear (I would put them on the shaft in the way the picture shows) but where goes the little fella far on the left?
Really need help here
Old 11-01-2016, 03:46 PM   #744
Hey Guys!
i ve been running a mach2 6.0T long time now with ceramic bearings the only thing i did to it.
Its been a few days till today that i took it apart it did some mumbly sounds in the gear mesh and i thought it was the sensor of the esc or something. but it wasnt. The motor struggles to turn the rotor at low RPM. i opened it, re-greased the bearings which roll just fine just like new and still nothing. its actually worse since i opened it. It just shakes the rotor at low rpm without spinning it.
Could it be the rotor dead , or...?
Thank you for your time!
grifind is offline   Reply With Quote
Old 11-11-2016, 06:56 PM   #745
nova2015's Avatar
Can anyone offer a recommended starting point for a Reedy Sonic Mach 2 21.5 for use in blinky touring car?
Been out of it for a little while, and don't want to kill the motor. Approximate FDR and timing recommendations please.
nova2015 is offline   Reply With Quote
Old 11-11-2016, 07:05 PM   #746
gigaplex's Avatar
I'm still narrowing in on setting mine up, but I run approx 30 degrees timing with 3-3.2 FDR. It seems pretty close to where it needs to be. Adding more timing just seems to add more heat without any observable lap time improvements. That's for a fairly large flowing outdoor track.
gigaplex is offline   Reply With Quote
Old 11-11-2016, 08:11 PM   #747
(0000000000)'s Avatar
On a 100' x 48' ozite track, I had mine between 3.6 and 4.0 fdr with just under 40' timing. Active cooling provided by a YR Tornado fan.
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 11-16-2016, 01:52 PM   #748
Any one know the part number for the reedy sonic m3 13.5 bearings??thanks,checked a main and had 2 different sets
X marksthespot is offline   Reply With Quote
Old 11-16-2016, 02:05 PM   #749
there 1/8 x 3/8 x 5/32
https://www.teamassociated.com/parts...l_bearing_set/
Rhett McNair is offline   Reply With Quote
Old 11-16-2016, 02:09 PM   #750
thanks for the help Rhett
