Old 06-11-2013, 09:31 AM   #676
Rick Hohwart's Avatar
Originally Posted by CraigM View Post
This is a cool item but please keep in mind that it may make the motor illegal for ROAR or IFMAR competition.
Originally Posted by mxgregg View Post
how's the Mach 2 4 .5 turn for modified touring car racing?
This is what the Reedy team drivers use. However I use a 5.0 in most cases.
Originally Posted by RCvetran View Post
mach 2 motors how do they compare to the old motors. Rollouts settings still the same.I run 13.5 and 10.5 .
13.5 is in blinky 1/12th scale and 10.5 both blinky and boosted in WGT10..
In a nut shell is it worth making the switch from the old motors to the new.
I think they are an improvement over the old version but I wouldn't think it is worth it to trash what you have any buy all new.
Originally Posted by Dirt_Burner View Post
I'm just getting into racing and built a Losi 22 buggy with orion vortex pro speedo and the Mach 2 13.5 motor. Running a 26T pinion. Any suggestions for settings with this combo?
I started with a b4.1 rtr and the reedy motor included in that kit seemed to be quite a bit faster...
The Reedy RTR combo is not slow so you might not see much difference in top speeds. The big difference will be in longevity, quality, and feel. You should be geared around 6.3:1 for maximum performance.
Originally Posted by luda View Post
Hi! Just wanted to know if anyone had advice on a suitable FDR for a mach2 13.5 on a track that has a long straight? The class is a boosted class and I am running the HW V3.1 ESC.
Thanks!
We don't run much boosted any more but my notes say 7.4:1.
Originally Posted by Yogi- View Post
I'm having trouble with a 21.5 not working. You have to turn the motor to get it going. Sometimes it will start other times u need to give it help. I haven't cooked it that I can tell.
It could be the sensor wire or the sensor itself. Did it ever work?
Originally Posted by JustWill75 View Post
I have a Mach2 17.5 and a LRP FLOW WORKS in my TC6.1 running blinky the track I race on is 70'x48' carpet on-road with good traction and very technical infield. What is a good starting point for timing and FDR? How would you set the Flow to work best with Mach2 in this type of track condition?
With a track the size of mine what temps should I be seeing?
The reason I ask is because I'm the only mach2 on the track and everyone else is talking about 120's. I had a really bad race night with my car and was told that maybe I should turn my timing down so I did and the car was way easier to drive.
I starting to think my bad setup is the reason I had to turn the timing down but I'm open to suggestions.
3.3:1 is a good starting point with timing at 45 degrees. To get the most out of your motor it will run hot. if you are running a motor fan you would be 150-170 degrees. Cooler is better but too cool means you are not pushing the motor hard enough.
Originally Posted by Chief View Post
Are the version 1 reedy motors still available? I'm looking for a 13.5 and thought they may be lower priced since the Mach 2's came out. Anyone seen any on the net?
We have not shipped any of these for a few months so they are probably going to be impossible to find.
Originally Posted by mschumi101 View Post
I fried my new Mach 2 17.5 yesterday, it went up in smoke. So I need a replacement! Is there any word on whether just stators are available from hobby stores? I can only find them on the Associated website with the super-high MSRP...
If it smoked in the first run the stator might be replaced free of charge or at a very reduced cost if you contact AE/Reedy.
Originally Posted by jag88 View Post
I have the Mach 2 4.5t and it's very noisy. I keep thinking I have a stone in my gears ... but I don't.
Is this normal for this motor ?
Any fixes ?
Thanks.
You can try and set the spacing so that there is no play or even a little tight. If you want to send it back to AE/Reedy we can take a look at it and try and fix it for you if it is really bad or there is some other problem creating the noise.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 06-11-2013, 09:49 AM   #677
mxgregg's Avatar
Trader Rating: 32 (100%+)
Thanks Rick. I really like my new Reedy. Super fast for sure.
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 06-12-2013, 12:31 AM   #678
What rotor size does the 17.5 stock mach 2 comes with?
zzztech is offline   Reply With Quote
Old 06-12-2013, 10:14 AM   #679
It comes with the #956 12.5 mm x 25 mm rotor.
www.reedypower.com
Old 06-13-2013, 11:43 AM   #680
jag88's Avatar
Rick, can I use a sensor board from a Reedy 17.5 Sonic in a 4.5 Reedy Sonic ?
Thanks.
jag88 is offline   Reply With Quote
Old 06-13-2013, 11:52 AM   #681
Thanks.
Yes as long as both motors are the same model (original or Mach 2).
www.reedypower.com
Old 06-13-2013, 12:01 PM   #682
jag88's Avatar
Can you give a 'rule of thumb' for shimming the rotor ? Does one direction give more torque and the other give more rpm ?
Thanks for your reply.
Old 06-13-2013, 05:46 PM   #683
big al's Avatar
I just recently picked up a used 21.5 and found that the endbell doesn't have stops machined in to the aluminum to stop the rotation of the sensor board. Has anyone else come across this?
big al is offline   Reply With Quote
Old 06-13-2013, 06:36 PM   #684
AE-Reedy
Is it the original version Sonic? The first batch of those did not have stops on the timing.
Sean Cochran is offline   Reply With Quote
Old 06-13-2013, 06:39 PM   #685
AE-Reedy
With shimming the rotor the first item that has to be correct is the gap from the rotor to the sensor. So in most cases you just use the shim that comes with the rotor on that end. You can then play with shims on the pinion end to set the end play for the bearings. You do not shim the rotor to change the performance of the motor.
Old 06-13-2013, 08:09 PM   #686
big al's Avatar
Thank you, Sean. makes sense now.
Old 06-14-2013, 01:21 AM   #687
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Will a Mach II sensor board work in a Mach I v2?
AWD
Old 06-19-2013, 11:19 PM   #688
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Is there a difference between the Mach 1 v2 stator and the Mach 2 stator? Specifically for the 17.5...
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-20-2013, 09:53 AM   #689
Default sonic 550 4 turn
Anyone know the stock timing for this motor, got one used and want to set it up factory
Rick442 is offline   Reply With Quote
Old 06-20-2013, 11:50 AM   #690
AE-Reedy
20 degrees
SEO by vBSEO 3.5.0
