Old 05-08-2013, 07:53 AM   #661
In England I can assure you Rc racing makes you a whole less attractive when you first tell a woman it's one of your hobbies haha
Mi4cxl is offline   Reply With Quote
Old 05-08-2013, 03:23 PM   #662
CraigM's Avatar
Trader Rating: 34 (100%+)
http://www.redrc.net/2013/05/jconcep...-timing-cover/
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-08-2013, 04:11 PM   #663
mxgregg's Avatar
Trader Rating: 32 (100%+)
how's the Mach 2 4 .5 turn for modified touring car racing?
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 05-11-2013, 03:35 PM   #664
Default mach 2 motors
mach 2 motors how do they compare to the old motors. Rollouts settings still the same.I run 13.5 and 10.5 .
13.5 is in blinky 1/12th scale and 10.5 both blinky and boosted in WGT10..
In a nut shell is it worth making the switch from the old motors to the new.
RCvetran is offline   Reply With Quote
Old 05-13-2013, 03:14 PM   #665
I'm just getting into racing and built a Losi 22 buggy with orion vortex pro speedo and the Mach 2 13.5 motor. Running a 26T pinion. Any suggestions for settings with this combo?
I started with a b4.1 rtr and the reedy motor included in that kit seemed to be quite a bit faster...
Dirt_Burner is offline   Reply With Quote
Old 05-14-2013, 03:52 AM   #666
Hi! Just wanted to know if anyone had advice on a suitable FDR for a mach2 13.5 on a track that has a long straight? The class is a boosted class and I am running the HW V3.1 ESC.
Thanks!
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 05-18-2013, 01:22 AM   #667
I'm having trouble with a 21.5 not working. You have to turn the motor to get it going. Sometimes it will start other times u need to give it help. I haven't cooked it that I can tell.
Yogi- is offline   Reply With Quote
Old 05-18-2013, 04:53 AM   #668
wingracer's Avatar
Trader Rating: 23 (100%+)
Usually that is sensor wire or the sensor itself.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-18-2013, 07:55 AM   #669
AdrianM's Avatar
+1
Try a new sensor wire.
Adrian Martinez
Old 05-18-2013, 02:31 PM   #670
JustWill75's Avatar
Send a message via AIM to JustWill75
I have a Mach2 17.5 and a LRP FLOW WORKS in my TC6.1 running blinky the track I race on is 70'x48' carpet on-road with good traction and very technical infield. What is a good starting point for timing and FDR? How would you set the Flow to work best with Mach2 in this type of track condition?
Originally Posted by Rick Hohwart View Post
125 and even 150 is not what I would consider hot. If you are really pushing the motor for max power and speed you would be around 180.
What is your gear ratio? and which car? In TC you would probably want to be around 45 degrees timing.
With a track the size of mine what temps should I be seeing?
The reason I ask is because I'm the only mach2 on the track and everyone else is talking about 120's. I had a really bad race night with my car and was told that maybe I should turn my timing down so I did and the car was way easier to drive.
I starting to think my bad setup is the reason I had to turn the timing down but I'm open to suggestions.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 06-09-2013, 08:30 PM   #671
Chief's Avatar
Trader Rating: 14 (100%+)
Are the version 1 reedy motors still available? I'm looking for a 13.5 and thought they may be lower priced since the Mach 2's came out. Anyone seen any on the net?
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 06-10-2013, 08:16 PM   #672
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
I fried my new Mach 2 17.5 yesterday, it went up in smoke. So I need a replacement! Is there any word on whether just stators are available from hobby stores? I can only find them on the Associated website with the super-high MSRP...
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-10-2013, 08:40 PM   #673
RedBullFiXX's Avatar
http://www.tqrcracing.com/shop/produ....asp?p_id=4539
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-11-2013, 07:59 AM   #674
jag88's Avatar
I have the Mach 2 4.5t and it's very noisy. I keep thinking I have a stone in my gears ... but I don't.
Is this normal for this motor ?
Any fixes ?
Thanks.
jag88 is offline   Reply With Quote
Old 06-11-2013, 08:23 AM   #675
mxgregg's Avatar
I also have a Mach 2 4.5 coming from a Orion 5.5 and I don't notice it being any nosier?
Any fixes ?
Thanks.
