Old 03-26-2013, 09:24 PM   #616
syndr0me's Avatar
Trader Rating: 32 (100%+)
My Mach2 6.5 arrived today. It's easily the nicest looking motor I've ever seen. I love the bling with how all the edges were machined after it was anodized. Very well done sirs.
Now, will it make me good at modified?
syndr0me is offline   Reply With Quote
Old 03-26-2013, 10:12 PM   #617
kinga's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Mornedn View Post
its already approved
The new part number is not on the roar approved list, only reedy sonic 941(for 17.5 for example) The mach 2 motors have different part numbers.
Are the mach 2 motors covered by the same ruling as the original reedy sonic motors?
kinga is offline   Reply With Quote
Old 03-27-2013, 12:28 AM   #618
evochick's Avatar
See this this link to the new approvals section on Roars website
http://roarracing.org/4rmb/forumdisp...ec-17-5-Motors
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 03-30-2013, 05:32 AM   #619
RC10B4_Mafco's Avatar
Send a message via MSN to RC10B4_Mafco
I pulled my Reedy Sonic 8.5 (not the Mach 2 version) apart to get rid of dirt, clean bearings etc. and I accidently didn't keep track of where the shims/spacers go. I put it back together the way I thought it should go and when I put it in my new B4.2 it made a screechy noise and I suspect it is the motor because I assembled it incorrectly. Does anybody have an exploded view of the motor (I have looked and cannot find one anywhere) or know where the shims/spacers go?
RC10B4_Mafco is offline   Reply With Quote
Old 04-03-2013, 05:31 PM   #620
B00t13g's Avatar
Double post.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-03-2013, 05:31 PM   #621
B00t13g's Avatar
I was driving today and I pulled off after about 4 minutes because my car felt weird. I temped my motor and it was at 170. My motor usually runs at 155-160 max. It now feels like it has a lot of drag brake. Any ideas?
Reedy mach 2 4.5 orca vx x ray t4.
The whole setup has 20 packs at most through it. Drive train is very free and spins well without the motor attached.
Mackenzie Meyercord
Old 04-03-2013, 06:57 PM   #622
ta04evah's Avatar
Usually all the smaller (inside diameter) shims go on the sensor side of the rotor, and the larger (inside diameter) shim go on the pinion gear side.
How did you clean your bearings and did you re lubricate them? if a small amount of grit gets inside the bearing while cleaning it will make a noise when you put it back into the car.
That could be a seized bearing in your motor, try turning the rotor while holding the motor in your hand, there will be some resistance due to the magnets but if it feels "tight" then it could be a bearing that's seized.
Cheers
Rob.
BSR BT-4 / Turnigy / Hobbywing / Savox / Trackstar
Castle Hill Raceway Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 04-03-2013, 07:01 PM   #623
B00t13g's Avatar
I appreciate the help, the motor spins freely when held by the rotor or it appears to anyway.
Mackenzie Meyercord
Old 04-03-2013, 07:11 PM   #624
ta04evah's Avatar
Ah ok. A thing that happened to mine was that on the larger bearing the metal shielding on one side collapsed and made the motor feel slower, but it also made a racket when the car was moving.
Not saying this could be the same thing, but just something to check just in case.
Cheers
Rob.
Old 04-03-2013, 07:34 PM   #625
B00t13g's Avatar
Definitely something ill have to look into. What worries me is why would it all of a sudden come off so much hotter after running less than half the norm. Esc was the usual 115-125.
Mackenzie Meyercord
Old 04-05-2013, 12:34 AM   #626
microrcdude's Avatar
Trader Rating: 70 (100%+)
Send a message via AIM to microrcdude
Purchased and installed a 17.5 Mach 2 to replace a seemingly tired Orion 17.5. Not impressed, but figured I would post to see if anyone has suggestions.
With the motors geared the same, the reedy out of the box was dead slow, but was still reaching 125 degrees. Timing was at 20 degrees out of the box.
Tried turning timing to 30 degrees, and the temps stayed about the same, but car had more top end.
Geared down 2 teeth, turned timing up to 40, and car felt the same. Still feels very sluggish, motor gets hot (150 degrees), still slower then my old dead orion.
Can't really tell if I just got a bad motor out of the box or what? I know it's not the car, as I just swapped motors with what was already in the car. Gear mesh is not too tight, checked it before and after each run.
Kyle @ Top Gear Hobbies
MayorRC.com
microrcdude is offline   Reply With Quote
Old 04-09-2013, 08:49 AM   #627
are you running boosted? What is your fdr? Track size?
Mornedn is offline   Reply With Quote
Old 04-13-2013, 09:30 AM   #628
Trader Rating: 27 (100%+)
Can anyone make a comparison of this motor and the D3.5 17.5? I'm going to need something to swap places with my D3.5 if I hit some bigger events this summer.
Team Losi LST
Warehouse Hobbies M5 Manta Ray
Stryker F-27C
J-3 Brushless Cub
platinumjason is offline   Reply With Quote
Old 04-13-2013, 04:46 PM   #629
narcotiks's Avatar
In my opinion the reedy is a better motor anyway... I have mine going better than all the d3.5s in both classes I have run in the past year.
So as for comparison, the reedy is just as fast as a d3.5.
narcotiks is offline   Reply With Quote
Old 04-14-2013, 12:23 AM   #630
the Reedy is bad!!! I got my mach2 17.5 and took it to the track yesterday. Motor smoked after only 3 runs. When temping it it was only temping at 80*
