Old 11-26-2012, 12:29 PM   #541
Default redbull
Thanks just what im looking for ,That covers the blinky, what about the 10.5 boosted ????? in WGT10.
Vinny
RCvetran is offline   Reply With Quote
Old 12-14-2012, 02:11 AM   #542
suggestions for Sonic 21.5 FDR in my FF03
New at this, is it...
I.D. (2.60) X (spur divided by pinion) = FDR
Please and thank you!
Track 80x45 roughly (pretty open)
I was told 4.576 but he has a different motor..
Oh, and I don't have a motor fanYet!
Gerald
M05-PRO // F104-PRO // FF03-PRO // XRAY T3'11
F1 race cars have one nut for their wheels, A.K.A. racenuts!
--one nut holding everything together--
racenuts is offline   Reply With Quote
Old 12-14-2012, 07:30 AM   #543
nolo148's Avatar
Ask Ed tomorrow, I'm pretty sure he's also running a reedy 21.5t
nolo148 is offline   Reply With Quote
Old 12-14-2012, 12:50 PM   #544
Thanks Owen!
Gerald
Old 12-18-2012, 07:05 AM   #545
eevul's Avatar
I am currently running 88/50 on my FF03 with the Sonic 21.5. I have also ran 80/53 but that felt slow. Current FDR is 4.58 and my temps are 160ish F with no fan.
eevul is offline   Reply With Quote
Old 12-18-2012, 10:31 AM   #546
Cool, I'll try those on the 29th! Will you be there for those practice days
Thank you
Gerald
Old 12-19-2012, 07:04 AM   #547
eevul's Avatar
Thank you
Yea, I'll be there on Saturday.
Old 01-27-2013, 09:04 PM   #548
flyradio's Avatar
Originally Posted by RedBullFiXX View Post
What is recomanded ratio n setup with Reedy Sonic 13.5t boost / LRP FLOW?
I got bad temp on x12
Team TRF Malaysia
flyradio is offline   Reply With Quote
Old 01-27-2013, 10:52 PM   #549
Trader Rating: 20 (100%+)
13.5 stators available for purchase? I need to rebuild my motor
goots is offline   Reply With Quote
Old 01-30-2013, 07:38 PM   #550
I took apart my reedy sonic 8.5 to clean it tonight and didn't pay attention to the placement of the spacers (the shaft side where the pinion goes.) There is a green o-ring, and 3 same size diameter spacers but different thinkness. Can someone tell me the order, including where the o-ring goes? thanks in advance.
liftmys10 is offline   Reply With Quote
Old 01-30-2013, 08:54 PM   #551
AdrianM's Avatar
Use the shims to try and get the rotor as close as possible to the sensor without it touching. Check this by putting a few shims on the sensor end of the rotor and sliding the end bell/sensor assembly on to the rotor. The remaining shims go on the output shaft and the o-ring goes on last.
Adrian Martinez
Old 01-31-2013, 03:41 AM   #552
Aaron_M's Avatar
Hi,
Sorry if this has been discussed before...
Reedy Sonic 10.5 on LRP Flow with V5 software. What endbell timing would people recommend?
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 02-05-2013, 08:56 AM   #553
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I have a 21.5 that has new bearings in it. It runs smooth, but when spun, feels like a brushed motor. I have a lot of motors and none of them have this odd feel, like its snapping too hard between magnetic poles. Shaft is straight, all spacers in the right place, nothing touching inside. I'm mystified.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-05-2013, 09:30 AM   #554
AdrianM's Avatar
Some people call it bump but the proper term is cogging. Some motors have more than others depending on rotor magnet strength, air gap between the rotor and stator and stator lamination design.
It is not a problem. You just figure out the timing and gearing for it in your application and it will be just as fast (or faster) as a motor with less cogging.
Adrian Martinez
Old 02-08-2013, 07:35 AM   #555
Radi0Flyer's Avatar
Going to try the 13.5 in my new CRC Xti. On a short tight track with a lot of braking/accelerating, does the motor still like a lot of static timing or will it get pretty hot? We usually only have a short straight with a sweeper where you are pinned so I don't know if setting up for max RPM will work. Should I instead run lower on the static for better torque and some dynamic for the one straight?
Sean
I'll drive it til the wheels fall off and burn
Radi0Flyer is offline   Reply With Quote
