Old 11-21-2012, 11:55 AM   #526
Rick Hohwart's Avatar
Reedy Cyber Monday Sale
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 11-21-2012, 01:04 PM   #527
mike ivy's Avatar
Trader Rating: 50 (100%+)
Nice!!!
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 11-22-2012, 11:41 AM   #528
geeunit1014's Avatar
Originally Posted by eevul View Post
I picked up a Sonic 13.5 for my CRC WGT at the end of last year's indoor season and I have been struggling to get this thing to keep up with everyone else. My car is slow down the straight and slow in the infield. I was running an LRP 13.5 before and it was faster. Can anyone recommend a good setup? I am running the following:
- LRP SXX V2 Stock
- ThunderPower 5400 65c
- 13.5 Sonic (stock rotor)
Track size is approximately 80x50 with the average lap times around around 10 to 11 second for WGT. This is for boosted class as well. I have tried some other suggestions from this forum but still haven't found the right setup. The guys running the LRP SXX V2 with the LRP x12 motors are killing me down the straight. They are running 55mm to 58mm rollout.
What settings are you currently using?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-23-2012, 05:53 AM   #529
eevul's Avatar
I am currently running 0 / 8 / 9 / 4 and have tried 0 /10 / 10 / 0. Would 0 / 10 / 12 / 0 work? Timing in the motor was tested using the stock settings, and now is 35 degrees (mine is the second gen Sonic with the updated timing marks).
I read somewhere that I should be setting this ESC to blinky mode and crank the timing. Then, start adding timing and boost and gear down as needed and watch my temps. Is that a good way to start with these things? I'm fairly new to brushless so any help is appreciated. I bought a second Reedy Sonic 21.5 for my FF03 running on blinky and it runs great with the stock settings.
eevul is offline   Reply With Quote
Old 11-23-2012, 06:58 AM   #530
First thing to know on the stock spec, stick to the even # boost profiles. The odd # ones are slow ramp, and that will make it feel very slow. I would go with 0/8/10/x on the esc, and turn the timing down on the motor to 30*. You shouldnt need a lot of motor timing in boosted, and you might find you could do with even less. You didnt mention what rollout you were at, but I would try gearing up from where you are 2 teeth or so
Mike Gee
Old 11-23-2012, 09:00 AM   #531
Can someone explain to me what these numbers mean? " 0 / 8 / 9 / 4 "
jha07 is offline   Reply With Quote
Old 11-23-2012, 09:45 AM   #532
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Flow setup Instructions
http://www.lrp.cc/fileadmin/lrp_anle...w-manual-e.pdf
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-23-2012, 10:16 AM   #533
Originally Posted by RedBullFiXX View Post
Thanks. I didn't realize it was a LRP specific thing.
Old 11-23-2012, 12:04 PM   #534
Originally Posted by jha07 View Post
How do you find the torque with your setting?
I started with that gearing with less timing and found the motor really woke up when I increased the timing with less gearing.
Torque is fine on more open layouts although the tighter layouts (12 second laps) I think would be better around 4.0FDR with higher timing. Maybe I will give it a try tonight.
Kane-o is offline   Reply With Quote
Old 11-26-2012, 06:16 AM   #535
eevul's Avatar
Thanks I will try that. I've been playing with rollout from 65 to 75 while trying to figure this thing out.
Old 11-26-2012, 09:14 AM   #536
Default 10.5, 13.5 and 17.5 in pan car classes looking for some advice
I run 1/12th pan car and WGT10 .
Classes in Uk are 1/12th 17.5 and 10.5 blinky in both looking for rollout and motor timing.
Been told by reedy driver in Uk set up for 10.5 blinky is motor 40 degree of timing and 65mm rollout ????
So looking for the same in 17.5 blinky 1/12th
WGT10 is running 10.5 boosted and maybe 13.5 blinky soon.
Any help txs in advance. Im running both associated cars with the updated LRP SXX version 2 with new boards fitted.
RCvetran is offline   Reply With Quote
Old 11-26-2012, 10:29 AM   #537
Trader Rating: 40 (100%+)
I like 80-105 ish depending on the track and anywhere from 30 to Max timing again depending on track On our local small technical track I am down to 86mm with 36 degrees
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 11-26-2012, 10:50 AM   #538
Default jason for what motor ????
Having said that range is so wide , I race 90% of the time indoors carpet 12=16 meters wide and 30 metres long
Old 11-26-2012, 10:57 AM   #539
Our carpet track is similar in size to that
Most of the Sonic Racers run 40deg with the following roll
17.5: 100 ish
13.5: 90 ish
Old 11-26-2012, 11:29 AM   #540
Yea out track is small here locally at about 10M x 15m and narrow lanes but when we go States side we get up to 18x30m
Jason Deadman
