Old 10-30-2012, 07:19 AM   #496
Rockin G's Avatar
Originally Posted by B00t13g View Post
On my reedy 17.5 if I just barely give it any throttle with the car on a stand it will make a weird grinding noise and the pinion will move slightly back and forth. When I say barely I mean a hair past neutral. Motor is extremely smooth elsewhere and performance is spot on. Is how it acts with barely any throttle normal? I've never really noticed it before as I have no reason to give it that little throttle.
Yokomo bd7
Reedy 17.5 max timing, 3.9 fdr with fan comes off at 165 after 6.5-7 minutes. 180 is the highest the motor has seen. Less than 20 packs through it.
Orion r10 pro drrs at 9 blinky. I've tried two different sensor wires and have re calibrated the esc. Thanks.
I have had 2 motors (one Reedy and one Trin) do that grinding sound that you described. One was a bad sensor BOARD. (Trin) and the other was a bad ESC.
1. Have you tried another motor on your ESC to rule out the ESC?
2. Since you have already switched sensor wires, it probably is not the wire. If it is not your ESC or your wire, then in MY experience, there is a good chance that it is the sensor board.
Rockin G is offline   Reply With Quote
Old 10-30-2012, 07:46 AM   #497
I would be a little more concerned with the pinion moving back and forth... How much fore/aft play does the rotor have inside the stator? Have you ever pulled the motor apart, or is it box stock?
JamesL_71 is offline   Reply With Quote
Old 10-30-2012, 08:51 AM   #498
Super Moderator
Slo_E4's Avatar
Trader Rating: 58 (100%+)
Yokomo bd7
Your neutral width is too low. Bump it up a few and I bet it goes away.
Slo_E4 is offline   Reply With Quote
Old 10-30-2012, 09:21 AM   #499
B00t13g's Avatar
I've tried 9% neutral width same issue. I don't recall my schurr speed doing this so I guess it is the sensor board. At least that's $12.
B00t13g is offline   Reply With Quote
Old 10-30-2012, 12:39 PM   #500
B00t13g's Avatar
Ordered another motor and a sensor board. No harm in having a spare 17.5 reedy
Old 10-30-2012, 01:32 PM   #501
Laguna Bozo's Avatar
9 is too low. Try 30...
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 10-30-2012, 02:06 PM   #502
AdrianM's Avatar
Originally Posted by wtcc View Post
Has anyone ever tried a Reedy Sonic 10.5t boosted? Can this motor take boost well? I ask because my club wants to use this one as stock motor for the club championship without limiting the used escs. So everyone will run this motor boosted...
It runs fine boosted. No problem at all.
Adrian Martinez
Old 10-30-2012, 02:27 PM   #503
B00t13g's Avatar
The r10 has 6,9 and 11. I've always run 6 with every car and motor combo.
Old 10-30-2012, 05:07 PM   #504
B00t13g's Avatar
I found for me that 49 degrees of timing and gear to temp works best. I ended up at 96/49 which is a 3.91 which worked best for me.
Old 10-31-2012, 09:16 AM   #505
I'm wondering what's a good starting point for boosted settings and gearing for 17.5 TC?
I'm currently running blinky, 48 timing, FDR 4.
jha07 is offline   Reply With Quote
Old 11-01-2012, 10:59 AM   #506
CL
CL's Avatar
Trader Rating: 32 (100%+)
What should the FDR be for a 5.5T with no timing?
Believe in yourself!
CL is offline   Reply With Quote
Old 11-06-2012, 02:24 PM   #507
I've also found that this motor, the 17.5T, likes a lot of timing. I tried gearing up with lower timing, 36-40, and just didn't have any torque. The first time I felt like this motor woke up was when I geared down and turned up the timing. I was up to 46 at my last race. I think it'll probably be better at 48-49.
Compared to others at my track, I'm geared quite a bit lower. Most run FDR 3.8-4, I'm at FDR 4.35. Has anyone else noticed that this motor needs a lower gearing than most motors?
Old 11-06-2012, 02:40 PM   #508
Trader Rating: 40 (100%+)
I keep going lower and lower each week and I am just getting faster. So yes. I am still playing with timing. On the bench I found that as I went up in timing no load other than the wheels and transmission once I got about 30 degrees it peaked then started to drop off the more I went up. This of course is by the sound and nothing more. I am going to look into a chassis dyno (DIY) at some point to be better at testing different gearing and timing settings just to get some data behind my setting changes
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 11-06-2012, 09:22 PM   #509
B00t13g's Avatar
I've now found that gearing up and turning up timing works about the same power wise as gearing down and lowering the timing.
Old 11-07-2012, 07:27 PM   #510
whiteflagwar's Avatar
Anyone know where I can find a replacement end bell (motot mount end of the case) for a reedy 540 motor? Thanks
Cole Liggett
whiteflagwar is offline   Reply With Quote
