Old 09-13-2012, 08:03 AM   #451
My fan is the one that is used in the Tekin RX8 esc. Is that good enough or is there a better one?
schaubro is offline   Reply With Quote
Old 09-13-2012, 08:18 AM   #452
geeunit1014's Avatar
Side Piece Racing Seis fan.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 09-18-2012, 05:56 AM   #453
B00t13g's Avatar
Is this motor like most 17.5s? Turn the timing all the way and gear to temp? If so, what should temp be after 6 minutes in rubber tire sedan?
B00t13g is offline   Reply With Quote
Old 09-18-2012, 06:12 AM   #454
Chaz955i's Avatar
Good question. I've had little luck with my Sonic. Very smooth but running timing the temps climb very fast 180+ and that is running a 4.0 FDR in blinky. For comparison my Duo 1 running in the middle timing position normally comes off around 157 and is considerably stronger all the way through. Other guys at the track are pulling a taller gear with the Sonic with more timing and coming off cooler so not sure if something is wrong with mine or I'm just approaching it completely wrong. It sure is smooth but is not near as fast as my old Duo.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 09-18-2012, 09:17 AM   #455
B00t13g's Avatar
I have the same issue with my motors in general. I flat out get motors hotter than most.
Old 09-18-2012, 10:52 AM   #456
Regional Moderator
CarbonJoe's Avatar
On the same track as Chaz955i, with my Sonic 17.5, I've been running around 145 - 165 degrees with an FDR of 3.8, depending on layout. I used to run with the timing advanced all the way, but backed off a bit it runs cooler with no loss of speed. I do run a fan blowing directly on the motor.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-18-2012, 10:55 AM   #457
B00t13g's Avatar
What timing are you at? I think im going to start at a 4.0
Old 09-18-2012, 01:05 PM   #458
AE-Reedy
On 17.5t motors I would start with the motor timing at 40. Most likely you can run more. If you max timing immeadiately you make the gear window very narrow. I prefer to start with less timing find what gear works for you then carefully start adding timing. Keep in mind as you increase timing you will have to gear down, smaller pinion.
Motor should always stay below 200. Optimum temp range seems to be 170-175. Also I think you must run a fan on the motor.
Sean Cochran is offline   Reply With Quote
Old 09-18-2012, 01:19 PM   #459
wingracer's Avatar
Trader Rating: 23 (100%+)
I find anything over 38 is no faster, just runs hotter and falls off more. A little less timing with a little more gear is better. This is on a 13.5 though so maybe 17.5s are different.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-18-2012, 03:55 PM   #460
Chaz955i's Avatar
No doubt Joe. I thought it could be the result of binding somewhere in the drivetrain but the other motors run cool with equivalent FDR. Weird. Your car is certainly not hurting for motor either. Makes me think the one I have is just on the weak side. When I ran Seaball's car it was a rocket, which is one of the reasons I went with the Sonic. The 13.5 I'm running in WGT seems to be much closer performing to the competition, at least at the local level.
At The Gate Bizzos
Old 09-18-2012, 04:44 PM   #461
Mr RCTech's Avatar
+1
That's exactly what I do at the track.
I always run around 160-165 F on the motor.
Usually drop 2-3 teeth on gearing then add more timing.
Also, run zero degrees on motor timing.
Mr RCTech is offline   Reply With Quote
Old 09-18-2012, 04:48 PM   #462
Regional Moderator
CarbonJoe's Avatar
Not an option in blinky.
Old 09-18-2012, 09:15 PM   #463
B00t13g's Avatar
Unfortunately my gearing window is even smaller than normal as the tallest I can go is 3.9 as far as I know.
Old 09-18-2012, 11:22 PM   #464
B00t13g's Avatar
How do the timing marks work on the reedy(how many degrees is each tick), and what is base timing at the middle or 0 position? Thank you!
Old 09-18-2012, 11:29 PM   #465
Not sure if it's been discussed before but does anyone have any experience with track debris getting into the motor via those cooling holes?
That's my one big concern about getting a vented can motor.
jjjheimer is offline   Reply With Quote
