Old 08-26-2012, 09:24 AM   #436
Chief's Avatar
Trader Rating: 14 (100%+)
Originally Posted by wingracer View Post
Same here. They are pigs in boosted until you really throw an assload of timing at it, then they start to move. Fortunately, they can take it.
How much timing and boost are you running. I have the same set up (RS-17.5)
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 08-26-2012, 09:38 AM   #437
wingracer's Avatar
Trader Rating: 22 (100%+)
I was running 13.5 1/12th with one. Had to pretty much max the RS with about 15-20 degrees of physical timing. Everyone has gone blinky now so haven't done any recent testing.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-26-2012, 10:43 AM   #438
Originally Posted by CraigM View Post
Andy Moore and Hara both run the sonic
Kevin H and Olly too. They are the business in mod
Thanks for the reply/info CraigM.
JoeyE is offline   Reply With Quote
Old 08-26-2012, 08:12 PM   #439
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Logi Maker View Post
Looking to run a Sonic in 17.5 1/12.. anyone running it and any tweeks to speak of?
Check out the Masrhit setup HERE
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-26-2012, 11:46 PM   #440
Trader Rating: 20 (100%+)
PM sent
goots is offline   Reply With Quote
Old 08-27-2012, 09:41 AM   #441
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Yeah buddy.
Thanks for all your info on the 1/12 scale.....
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 08-27-2012, 09:45 AM   #442
Yeah buddy.
No problem
12th scale season is about to commence again
Old 08-27-2012, 11:10 AM   #443
Logi Maker's Avatar
No problem
Sept 15th for us and the NW big one, Timezone Grand Prix, in Nove 9-11..
Kyle Predmore
B6D|B64D
Old 09-08-2012, 02:56 AM   #444
Hi,
I have a Reedy Sonic 10.5. I believe that it is an earlier version as the later one has timing in numbers on the end bell but mine has small lines only.
Can anybody tell me or can point me in the right direction for a diagram to what amount of timing the lines mean.
Thanks in advance.
Bryan D is offline   Reply With Quote
Old 09-08-2012, 07:50 AM   #445
Originally Posted by Bryan D View Post
Hi,
Thanks in advance.
http://www.rctech.net/forum/10070952-post141.html
http://www.rctech.net/forum/10156241-post193.html
http://www.tqrcracing.com/shop/produ....asp?p_id=4449
Old 09-08-2012, 08:15 AM   #446
Thanks RedBullFiXX for the info.
Old 09-12-2012, 11:02 PM   #447
Hello,
I run a Reedy Sonic 17.5 in my TC6.1 in blinky mode. It runs fine, but the other cars on the track seem to have more acceleration. I am thinking that if I switch to a different rotor, I will gain some more torque and thus acceleration. Is this correct?
If I have things correct, the 954 rotor is one that came with the motor. The 955 is the next one with more torque, the 956 would be high torque. By changing the rotor is the motor still roar spec legal?
Since I may be taking the motor apart to change the rotor, will I gain anything if I change the bearings to ceramic ones? Is it worth the effort? Will they stay together in a crash?
thanks,
tim
schaubro is offline   Reply With Quote
Old 09-12-2012, 11:09 PM   #448
Originally Posted by schaubro View Post
Hello,
thanks,
tim
The sonic comes with the spec torque rotor. Maybe you can give us your Fdr and timing just so we can see what settings you have
Old 09-13-2012, 07:15 AM   #449
FDR = 4.0
Timing = 35 degrees
Old 09-13-2012, 07:33 AM   #450
geeunit1014's Avatar
FDR = 4.0
Timing = 35 degrees
Run more timing. I run 4.0 and 41ish* in my 6.1. Make sure you have a good fan
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
SEO by vBSEO 3.5.0
