Old 08-15-2012, 05:14 PM   #421
hanulec's Avatar
Trader Rating: 25 (100%+)
Originally Posted by geeunit1014 View Post
A better fan will get you another 10-20* off the motor, integy fan/heatsink combos aren't really that effective, and that heatsink may be hurting you. I would suggest a side piece racing seis fan. If you can, try to get a baseline in more ideal conditions, as james said there's pretty much no way your gonna be under 200 with those conditions. If you have a setup that runs 170-180 when its more ideal, then its not such a big issue if you get over 200 when the conditions get hot.
Listen to Hammy... He knows what is up
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-16-2012, 03:44 AM   #422
wtcc's Avatar
Check to see if either the rear bearing housing or the rotor is tweaked. Loosen the 3 screws that hold the motor together slightly and roll the motor, you will see the can wobble if this is the case
Thank you for all the good answers! Looks like Mike is right. Something inside is not straight. I get an exchange motor on saturday
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 08-18-2012, 02:07 PM   #423
Trader Rating: 20 (100%+)
Does anyone know what the dot code for the 3 stock rotors are? I have seem to lost my notes on it.
goots is offline   Reply With Quote
Old 08-18-2012, 08:57 PM   #424
narcotiks's Avatar
I think the dots are for balancing purposes because i gone through a few motors and every a rotor that came with one motor that was 12.5 had a different dot code to another rotor that came with another motor that was 12.5.
Measure them with callipers?
narcotiks is offline   Reply With Quote
Old 08-19-2012, 12:12 AM   #425
wtcc's Avatar
Got my exchange motor yesterday. My car is back to a normal noise level now = gears only. Unfortunately there were no differences in laptimes. Tenperature seems a bit lower though...
Old 08-25-2012, 04:13 AM   #426
how does the reedy 17.5 motor perform in boosted stock? any good or are they just for blinky classes?
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 08-25-2012, 04:37 AM   #427
Blinky only !
RCMAKER | BITTYDESIGN | MUCHMORE
Lionel S is offline   Reply With Quote
Old 08-25-2012, 10:14 AM   #428
I found it to be very fast with my RS setup. It does need allot of timing to get it to rip tho.
Old 08-25-2012, 10:15 AM   #429
Originally Posted by Lionel S View Post
Blinky only !
I ran this motor in blinky and boosted 17.5
Old 08-25-2012, 11:10 AM   #430
Super Moderator
Slo_E4's Avatar
Trader Rating: 58 (100%+)
I ran boosted sonic 17.5. Very smooth, not too much rip, not too little.
Slo_E4 is offline   Reply With Quote
Old 08-25-2012, 12:24 PM   #431
Blinky only !
wat
JamesL_71 is offline   Reply With Quote
Old 08-25-2012, 05:57 PM   #432
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Looking to run a Sonic in 17.5 1/12.. anyone running it and any tweeks to speak of?
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\Schelle
Logi Maker is offline   Reply With Quote
Old 08-25-2012, 09:22 PM   #433
wingracer's Avatar
Trader Rating: 22 (100%+)
Same here. They are pigs in boosted until you really throw an assload of timing at it, then they start to move. Fortunately, they can take it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-25-2012, 10:25 PM   #434
Trader Rating: 26 (100%+)
Any pro drivers using the Sonic mod motors? Looking to get a mod motor. I just want to see what people are using.
Thanks~~!
JoeyE is offline   Reply With Quote
Old 08-25-2012, 11:11 PM   #435
CraigM's Avatar
Trader Rating: 34 (100%+)
Thanks~~!
Andy Moore and Hara both run the sonic
Kevin H and Olly too. They are the business in mod
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
