Old 07-18-2012, 01:49 AM   #376
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Slo_E4 View Post
That's pretty crazy you can't adjust timing. Something is binding. Take a look at this post in regards to shim's placement.
Reedy Sonic
That works great thanks! Now to get this timing adjuster to work...it's actually solid! Can't make it budge
svndayNZ is offline   Reply With Quote
Old 07-18-2012, 05:10 PM   #377
Leester's Avatar
Trader Rating: 20 (95%+)
Default 13.5 stock rotor Part #
Does anyone know the dimensions or the part number for the stock rotor that comes in the 13.5? Is it #954 12.3 x 24.2 x 7.25mm; #955 12.3 x 25 x 7.25mm; or #956 12.5 x 25 x 7.25mm?
Leester is offline   Reply With Quote
Old 07-18-2012, 05:20 PM   #378
wingracer's Avatar
Trader Rating: 22 (100%+)
It's supposed to be the 12.5 but mine was smaller, like 12.41 x 24.5. I bought the 12.5 and it was bigger. Picked up about a tenth with it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-18-2012, 07:25 PM   #379
Leester's Avatar
I measured mine also (4-5 times) and got the same measurements you described. So the #956 is actually bigger. Go figure. Thanks wingracer. It's what I wanted to know in both dimensions and performance
Old 07-22-2012, 03:09 AM   #380
narcotiks's Avatar
Had this problem today when putting a new motor in, take the plastic cap off to reveal the sensor circuit board, there are three holes for the screws to go in, take a pair of needle nose pliers and put one end in two of the three holes and very lightly turn the sensor assembly, it will work
narcotiks is offline   Reply With Quote
Old 07-22-2012, 08:56 AM   #381
Mr RCTech's Avatar
Is this the same motor as the Reedy??
Most guys at the track thinks so..
http://www.hobbyking.com/hobbyking/s...or_3040KV.html
Mr RCTech is offline   Reply With Quote
Old 07-22-2012, 10:22 AM   #382
Madulla's Avatar
Nope. Looks more like a X20 LRP copy.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 07-22-2012, 10:56 AM   #383
wingracer's Avatar
I think you need some new glasses, it looks nothing like anything LRP. It's clearly from the same mold so to speak as the Reedy and TP.
Team Shepherd USA
Old 07-22-2012, 11:09 AM   #384
Skiddins's Avatar
Most people also thought the Thunder Power's were the same as the Reedy's, they aren't.
Only way is to measure all the internals.
All the outer components look different as well.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-22-2012, 03:38 PM   #385
narcotiks's Avatar
Hey guys I've got a 21.5 motor and I want to get a different rotor but there are two different lengths with the same diameter rotor that I want. Take a look http://www.teamassociated.com/reedy/parts/details/955/
http://www.teamassociated.com/reedy/parts/details/954/
Which one do I get ??
Old 07-22-2012, 05:28 PM   #386
wingracer's Avatar
I would say neither, get the 12.5 x 25 x 7.25
Team Shepherd USA
Old 07-23-2012, 02:45 AM   #387
narcotiks's Avatar
That's the one I'm already using (came with motor) Want to get a high rpm rotor.
Old 07-23-2012, 03:00 AM   #388
wingracer's Avatar
Measure it. I bet it's not.
Team Shepherd USA
Old 08-06-2012, 11:34 AM   #389
Rockin G's Avatar
Originally Posted by Sean Cochran View Post
TC
Reedy Sonic 17.5t used standard rotor, 12.5mm
36 degrees timing, 3.84 gearing
Sean, or any....Just picked up the 17.5 Reedy to run in 1/10 TC in blinky mode. Is this still a good starting point or has more testing been done? If so, where should we start? Thanks in advance.
Rockin G is offline   Reply With Quote
Old 08-06-2012, 01:55 PM   #390
wingracer's Avatar
I'm a different Sean but I would say that sounds in the ballpark. As I was discussing earlier, you might want to measure your rotor to see what you actually have.
Team Shepherd USA
