Old 07-09-2012, 04:07 AM   #361
chrisk's Avatar
Trader Rating: 32 (100%+)
After reading some good reports for the 21.5 motor in blinky, I have just picked up one, so we will see if it gives that little edge.
What timing and temps are you looking at with the 21.5 in blinky
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 07-09-2012, 07:21 AM   #362
Nico''s Avatar
Originally Posted by narcotiks View Post
If you read the page before there is a post with information to your question.
Hi,
my question was badly written, sorry, I know stator, sensor, rotor are different, but I mean, on the tracks, what are the difference between Sonic 10,5 et Thunder power 10,5 please?
Nico' is offline   Reply With Quote
Old 07-09-2012, 04:25 PM   #363
Monsta's Avatar
im running 40deg timing with 2.9-3.1fdr and am sitting on 40-45c at the moment. air temp is around 15c as well.
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 07-09-2012, 05:18 PM   #364
chrisk's Avatar
thanks Monsta
It has been colder than that of a Tuesday night in Sydney of late
I had been running 2.8 with an Orion sitting on about 60 c motor temp
so i will look at yours to start with
smaracing.org
Old 07-09-2012, 07:23 PM   #365
Monsta's Avatar
No worries.
Yeah, thats middle of the day. Nights are in the minus' down here
1:1 racer
Old 07-10-2012, 05:54 AM   #366
Paul.Spencer's Avatar
Go to an FDR of 2.6 55/42 timing backed back to around 35
Mild to Wild RC | DeadStarRC.com |ACE Hobby Australia |
TEAM Associated TC6.1WC |Team Orion | Reedy| Sweep
TEAM Associated 12R5.2 |Team Orion| Reedy| Matrix
TEAM Associated B44.1.5 |Team Orion| Reedy| Sweep
TEAM Associated B8.2eFT |Team Orion | Reedy| Sweep
Paul.Spencer is offline   Reply With Quote
Old 07-10-2012, 07:17 AM   #367
SlideMasteR's Avatar
anyone have a base fdr for boosted setup Reedy 13.5 with HW V3 / SP on mid size track 40m x 20m
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 07-10-2012, 08:40 AM   #368
daleburr's Avatar
6.8 with the ESC on max boost/turbo should be about right.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 07-13-2012, 11:12 PM   #369
svndayNZ's Avatar
Trader Rating: 20 (100%+)
I just picked up a sonic 13.5 and I'm really happy with it, only I can't advance the timing above 20 deg which is stock. It's running really cool with a mid 5 fdr, is it common for these things to be jamming like this?
svndayNZ is offline   Reply With Quote
Old 07-13-2012, 11:20 PM   #370
narcotiks's Avatar
Have you loosened the three screws on the rear cap that the sensor cable goes into? if you have and it isn't moving, undo the screws, take the cap off, blow out the inside of the motor with compressed air, check for any debris, re assemble and try again.
narcotiks is offline   Reply With Quote
Old 07-13-2012, 11:41 PM   #371
svndayNZ's Avatar
Yea if done all that, I'll give that a try. If only used it two three times
Old 07-14-2012, 12:38 AM   #372
narcotiks's Avatar
Check if the actual sensor assembly itself is free moving aswel.
Old 07-17-2012, 09:06 PM   #373
svndayNZ's Avatar
The sensor isn't moving at all. The motor works absolutely fine I just cannot adjust the timing on is thing. When I next get near ann air compressor I'll give it a clean out. Another question I removed the can too see if it wasnt an issue here, however the re are two shims, a narrow and a slightly fuller that sit on the end shaft, which one goes on first?
Old 07-17-2012, 09:37 PM   #374
Super Moderator
Slo_E4's Avatar
Trader Rating: 57 (100%+)
That's pretty crazy you can't adjust timing. Something is binding. Take a look at this post in regards to shim's placement.
Reedy Sonic
Slo_E4 is offline   Reply With Quote
Old 07-17-2012, 11:25 PM   #375
narcotiks's Avatar
Wait so at the back of the rotor there is a gold shim, a thick one, but is there another thin metal shim? Because I was cleaning out my sonic the other day and one of these appeared on my work bench, I had some thicker ones aswell laying around, so I thought it was just from them, but now looking at that picture I'm abit confused ! If there is a shim before the gold one at the back, can someone measure the thickness for me so I know which one to put in. Thanks.
