Old 06-25-2012, 02:51 PM   #346
P6
so with a esc that has mod setting boost/turbo should i turn the motor timing to 0 or leave it at twenty like it game with
P6 is offline   Reply With Quote
Old 06-25-2012, 04:13 PM   #347
AE-Reedy
It depends on your situation. Most cases begin with the timing in the factory setting and adjust from there.
Sean Cochran is offline   Reply With Quote
Old 06-26-2012, 02:02 AM   #348
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by S_fender View Post
Not sure, it depend on your speedo.
Last week-end i've run on a "huge" track (european style).
With my sxx v2 speedo, 4.0 soft + 4.5 sonic, i should put max motor timing (30° on the old can) and 1.5.6.3 for the speedo.
I've lost time to find the setup as i was afraid to put lots of motor timing.
But i' ve remember that x-12 have a minimum timing of 27.5° .
I know 4.0 would be best but sometime 4.5 with lot of timing have a better feeling.
Sébastien
That's a fair bit of timing and boost and punch! Must be a big track! I used to run 25 degrees timing with the sxx v2, but now a bit less with the hobbywing v3 because it's got more power
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-26-2012, 11:03 PM   #349
P6
the outdoor track is higher speed with a long straight and im running the brushlesshobbies 120a esc with mod settings 65c shorty lipos just not sure if i should time it at 0 and mess with the esc settings or leave the timing at 20 and work my way from their with the esc the rest of the way
Old 06-26-2012, 11:11 PM   #350
trigger's Avatar
Hi guys, just bought a sonic17.5. Throughout my runs my motor came off at around 150s F. With a fan. Is that too hot or am I ok. I run no timing and my gearing is 95/51 which is 3.72
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 06-27-2012, 01:38 AM   #351
Trader Rating: 20 (100%+)
youre fine! I average 165-175 degrees in boosted 17.5
goots is offline   Reply With Quote
Old 06-27-2012, 05:27 PM   #352
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
where do these motors like the timing? im trying to tune my wgt with it and having some trouble figuring out rollout/timing curve for the motor. does it like mechanical timing or dynamic and where in the rpm range?
I tried tuning it with full timing through the whole range with zero bell timing, and leaving it at 20 as it comes, adding a little up top with more teeth. doesnt seem to matter what i do though, the car feels sluggish and doesnt really have the pull others do. its a smooth motor for sure. i dont get that suddent turbo jolt on the straight.
still figuring out this timing stuff. my lrp took a good while to figure out with the inserts ect.
rolling out around 70mm in all attempts.
valk is offline   Reply With Quote
Old 06-28-2012, 03:03 PM   #353
My 21.5 was sluggish out of the box. I blasted the bearings and re oiled them and kept racing. after 3 to 4 practice and race days the motor started to wake up. Now it has a lot of races on it. Temps have dropped, torque and rpm seem to have gone up, and I am extremely happy with the motor. Best of all it kept all of its smoothness. I'm running 40-42 on the endbell timing. I'm running a blinky class so I can't help with the esc boost settings. I don't have any problems keeping up with the revtech, d3, speed passion, or Novak motors in the same class. If I was in the market for another motor I would definitely go sonic again.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 06-29-2012, 11:43 AM   #354
R1wurks's Avatar
does anyone tried comparing lap times againts Duo 3.5 yet? just wondering...
D3.5 forum sounds like they might be a little bias.
r1wurks.com
r1wurks at gmail.com
R1wurks is offline   Reply With Quote
Old 07-05-2012, 12:45 PM   #355
Nico''s Avatar
Hi,
do you know if there is a difference between 10,5 Reedy Sonic and 10,5 Thunder power please?
best regards,
Nico'
Nico' is offline   Reply With Quote
Old 07-05-2012, 06:27 PM   #356
narcotiks's Avatar
Originally Posted by Nico' View Post
Hi,
best regards,
Nico'
If you read the page before there is a post with information to your question.
narcotiks is offline   Reply With Quote
Old 07-05-2012, 09:14 PM   #357
Professor's Avatar
+1, ive just purchaced a second sonic 21.5 for my f1, been running my 1st 21.5 in blinky in tc now for about 5 mths with good results & now alot of others in the class seem to be switching to the sonic
would also agree with 6376vette it did seem to be better after 2-3 runs
VBC RACING-R1 WURKS AUS--HOBBYWING--SILVERBACK--MAD GRAPHICS--BLITZ
Professor is offline   Reply With Quote
Old 07-05-2012, 10:11 PM   #358
Monsta's Avatar
The 21.5 has been my first foray into the brushless scene. i used to be running 3rd, 4th and 5th and now im taking 1st constantly in qualifying and mains!
Im now a Reedy man and never going back
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 07-08-2012, 10:53 AM   #359
Jimmy Morris's Avatar
Not yet in touring car but in 2wd buggy I had as much hp down the straight as my friend with a d3.5 and more punch too. As far as laps times, single fast lap to fast lap in the main, i was .1 or so faster. I really like these motors. I know different drivers is like apples to oranges, but its the only real comparison I've done.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 07-08-2012, 09:42 PM   #360
Nico''s Avatar
Hi,
do someone have compare Sonic 10,5 with Thunder power 10,5 please? ( or 13,5 sonic with Thunder power)
they look the same nut there are some little difference with the look and I guess the sensor in not exactly the same.
I have a thunder 10,5, it works pretty well, but I prefer look of Sonic, and I would like to know if it work as well with 0 timing from esc than the Thunder please?
