Old 04-10-2012, 02:47 PM   #301
Skiddins's Avatar
Originally Posted by Sean Cochran View Post
We do not have a date but we are looking into offering some stators.
We would probably start by offering a 17.5t stator as it is by far the most popular. Which wind are you looking for?
Just out of curiosity, why do you want replacement stators?
Repair burned up motors, or some other reason?
Trying to gauge how popular these might be.
Originally Posted by olhipster1 View Post
Agree.. with Mike
from what i've seen...most stators are from smoked up 17.5...a reason the other brand motor is popular is the ability to rebuild.
and changing the stator for those every now and then classes leads to big incentive to stick with Reedy.
Looking for 13.5's
I was trying to find the limit.... found the limit, hence needing a new stator ;-)
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-10-2012, 03:31 PM   #302
CW22's Avatar
Trader Rating: 93 (100%+)
Default Reedy Sonic 17.5T
Hi guys, when you guys mention a 40 degree timing, is that the last line #4 on the timing adjusted to the left side from zero position, please help me? I am new in this timing set up. Thank you.
CW22 is offline   Reply With Quote
Old 04-10-2012, 04:21 PM   #303
AE-Reedy
It sounds like you have the first version timing marks.
The newer motors have actual numbers assigned to the timing lines.
With your motor the line you describe would be 30 degrees.
40 degrees would approximately be the leading edge of the can screw.
Look at the attached photo.
Sean Cochran is offline   Reply With Quote
Old 04-10-2012, 04:31 PM   #304
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
We are for sure going to release a 17.5t stator. Other winds is undecided at this moment. It will probably depend on demand if we would sell other stators.
One problem I see with stator swapping in the Sonic is that each "can" is engraved with the wind. So if you have 13.5t and then you put in a 21.5t wind, the motor still says it's a 13.5t on the outside.
Look for the 17.5t stators in May, just guessing right now.
good news..
i would suggest thinking about releasing a 21.5 or 25.5 whichever is for VTA...even if in small batches are released you might be surprised on demand.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 04-10-2012, 05:19 PM   #305
CW22's Avatar
Default Reedy Sonic timing set up
Thank you for your replied.
From the picture you attached, it look like that is set up a full timing to the end? Because I saw the small plastic arrow indicated in the last line.
Am I looking at the correct way?
Old 04-10-2012, 05:38 PM   #306
AE-Reedy
The pointer is actually above the line. If you want 40 degrees timing that is my best estimate to achieve that.
Old 04-10-2012, 05:42 PM   #307
AE-Reedy
good news..
Are you asking for 21.5t stators? We already have 21.5t motors available.
We have been considering adding a 25.5t to our line also.
We need to do some more checking to see if we can make that wind and if it would be legal for competition.
Old 04-10-2012, 05:55 PM   #308
CW22's Avatar
Default Reedy timing set up
Thanks Sean, so the last line is the maximum to adjust to increase the timing.
I am using this motor on my Tamiya TA05 V2 with 94 spur gear/50 pinion gear it ran 140 degree on the motor. Anybody have a tip for me for a better gearing? To make it a bit faster on my car, please. Thanks.
Old 04-11-2012, 11:51 AM   #309
samnelso's Avatar
Do you guys have any suggestions for rollout and timing on a 13.5 blinky 12th scale? I found some info on 17.5 blinky and 13.5 boost, but not much on this. My current rollout is ~3.56" (90.4mm) with 40deg motor timing and my temps after 8min are ~146F. My car is certainly not slow, but I'm sure it could be faster. It was suggestion by a local I gear up a few teeth. I just changed to a rollout of 3.63" (92.3mm), but have not tried it yet. Advice would be much appreciated
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 04-11-2012, 12:01 PM   #310
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I think you're in the ballpark on that setup
On cool days -65f I've run 92 roll with max timing, and no fade
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-11-2012, 04:37 PM   #311
CW22's Avatar
Default Reedy 17.5T gearing
Can anybody help me with a tips, what size of gearing I should use for a Reedy sonic 17.5T motor on a Tamiya TA05, currently I am using 50 pinion/94 spur gear. Ratio 3.86 If I am not mistaken. I need a suggestion how to get a bit more power?thanks.
Old 04-11-2012, 04:45 PM   #312
AE-Reedy
The only thing I could suggest is maybe gearing up more. Just need to keep an eye on temps. I think you could go as high as 3.50 if temps don't get too hot. Keep the motor below 170F.
Old 04-11-2012, 04:53 PM   #313
CW22's Avatar
Default Reedy sonic 17.5T
Thanks, so I can't change the pinion gear to the higher number, because it will hit the motor casing house. Now I am using 50 pinion is very close to the edge. Is that mean I need to lower down the spur gear to like 92 or 90 maybe?
Old 04-11-2012, 05:41 PM   #314
dc661's Avatar
Trader Rating: 123 (100%+)
Yes go to down a lower Spur gear and adj your FDR from that Spur size. From there follow what Sean said with motor temps.
-DJ Cranmer
dc661 is offline   Reply With Quote
Old 04-11-2012, 06:01 PM   #315
CW22's Avatar
Default Gearing
Thank you for your advise. What is FDR? Is't Front Differential? thanks.
