Old 04-06-2012, 07:36 AM   #286
Skiddins's Avatar
Any news on when Reedy will sell stators separately?
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-06-2012, 07:44 AM   #287
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-06-2012, 10:51 AM   #288
Originally Posted by Sean Cochran View Post
The motor you have came pre-set with 15 degrees of timing. Top line on the plus side will be 30 degrees, line on the opposite end of the range would equal zero.
Sean, would you mind sharing the setup you ran @ the Carpet Nats for 17.5 12th?
Timing/rollout/rotor?
JamesL_71 is offline   Reply With Quote
Old 04-07-2012, 08:47 PM   #289
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Cleaning the motor, when putting it back together I'm wondering where the white insulator goes. Does it go on the back of the can (that's where I thought it came from) or between the solder tabs and the timing ring?
The timing ring is aluminum and looks like it would short out the outside solder tabs, but that insulator doesn't look like it would solve that problem either.
I looked at the motor manual but it doesn't have an exploded diagram; anybody know a link?
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 04-07-2012, 09:31 PM   #290
Super Moderator
Slo_E4's Avatar
Trader Rating: 57 (100%+)
I cleaned mine a few weeks ago and snapped pics just in case I forgot something. It was not cleaned yet in the pic. Here you go.
Slo_E4 is offline   Reply With Quote
Old 04-09-2012, 05:07 PM   #291
AE-Reedy
TC
Reedy Sonic 17.5t used standard rotor, 12.5mm
36 degrees timing, 3.84 gearing
12th
Reedy Sonic 17.5t used 954 rotor, 12.3x 24.2
36 degrees timing, 104.5mm rollout
Paul Ciccarelo
Ran a Reedy also to TQ, finish 2nd.
He ran with a standard rotor, more timing and a little less gear.
I felt like Paul was maybe a little faster than me the first minute, maybe two but after that I felt I was better than him. No imperical proof just gut feeling but I think with 1s the smaller rotor is more consistent through the 8 minute runs. But it does show both set ups run well.
Sean Cochran is offline   Reply With Quote
Old 04-09-2012, 08:52 PM   #292
chicky03's Avatar
Send a message via AIM to chicky03
TC
12th
Paul Ciccarelo
I was really happy with the motor, I had no prior testing to the race, i just took Masterhit's advice and went with that. That shows you how good the motor really is!!!! I ran 40 deg timing, stock rotor, 1.63 rear tires and 58/72 gearing. For the last main wil went to 38 deg timing with a 60 but I don't know how it would have finished as my king pin clip came out and my car was dragging on the track the last half of the race, so my laps don't mean much there.
Serpent America, Picco, Blitz Bodies, Team Titan, Desoto Racing, LRP, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa.
chicky03 is offline   Reply With Quote
Old 04-10-2012, 11:16 AM   #293
Trader Rating: 3 (80%+)
were these settings for 17.5 blinky or boosted ? thanks
traitor is offline   Reply With Quote
Old 04-10-2012, 12:30 PM   #294
AE-Reedy
Blinky class, hopefully boost is dead.
Old 04-10-2012, 01:05 PM   #295
Sean/Paul, thank you very much for the rollout info. It is very helpful.
I know neither of you were running WGT @ Nats, but I did see a number of Reedy Sonics in that class. Do you have a rollout/timing starting point for 13.5 non-timing WGT?
Old 04-10-2012, 02:24 PM   #296
AE-Reedy
I could be wrong, but this would be my starting point for WGT.
13.5t with standard rotor, 12.5mm, 36 degrees timing, 83mm roll-out.
The roll out is a total guess so I would probably run a couple minutes then stop to check the motor temp.
Old 04-10-2012, 02:30 PM   #297
AE-Reedy
We do not have a date but we are looking into offering some stators.
We would probably start by offering a 17.5t stator as it is by far the most popular. Which wind are you looking for?
Just out of curiosity, why do you want replacement stators?
Repair burned up motors, or some other reason?
Trying to gauge how popular these might be.
Old 04-10-2012, 02:39 PM   #298
MikeXray's Avatar
Trader Rating: 72 (100%+)
I have a few of that "other" motor that looks alot like the sonic, and you can easily reconfigure it for different classes, say 21.5 for F1, or 13.5, etc at 1/3rd the cost of a motor, its good for classes you only run on occasion. I also tend to burn out 17.5 stators 2-3 times more than I see a rotor getting weak.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-10-2012, 02:48 PM   #299
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Agree.. with Mike
from what i've seen...most stators are from smoked up 17.5...a reason the other brand motor is popular is the ability to rebuild.
and changing the stator for those every now and then classes leads to big incentive to stick with Reedy.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 04-10-2012, 03:37 PM   #300
AE-Reedy
Originally Posted by olhipster1 View Post
Agree.. with Mike
We are for sure going to release a 17.5t stator. Other winds is undecided at this moment. It will probably depend on demand if we would sell other stators.
One problem I see with stator swapping in the Sonic is that each "can" is engraved with the wind. So if you have 13.5t and then you put in a 21.5t wind, the motor still says it's a 13.5t on the outside.
Look for the 17.5t stators in May, just guessing right now.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
