Old 03-14-2012, 07:22 PM   #271
Trader Rating: 19 (100%+)
Hey guys, I just grabbed one of these motors and was wandering how i should gear it and set timing compared to a reVtech motor which i currently run with a 3.6 fdr and full timing on a 100x48ft indoor track. Any help will be appreciated. Thanks! -Randy
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 03-14-2012, 07:48 PM   #272
geeunit1014's Avatar
At MRH I always run my sonic at a 3.76 and 40* timing.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-14-2012, 07:54 PM   #273
so possibly like a 3.4 at the C? and 40* timing
★Randy Banks★
Old 03-14-2012, 08:50 PM   #274
Id start with the same setup and go from there. I feel like 3.76 is a little overgeared when the traction isnt ridiculous at MRH, so it should be real close up there.
Mike Gee
Old 03-15-2012, 09:01 AM   #275
The_Punisher's Avatar
I am looking for setup tips for 17.5 boosted, running LRP SS V2. What a good FDR to have, and what rotor works best in the sonic. Track avg lap time is 8.3sec.
The_Punisher is offline   Reply With Quote
Old 03-15-2012, 09:43 AM   #276
Infinite 12th's Avatar
I also had a similar question here but concerning 13.5
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 03-15-2012, 02:10 PM   #277
LOSI123's Avatar
Trader Rating: 63 (100%+)
Does anyone know what the 20 mark is on the newer mod motors?
like what real internal advance is it at 20
LOSI123 is offline   Reply With Quote
Old 03-15-2012, 06:05 PM   #278
nicorozog's Avatar
Send a message via MSN to nicorozog Send a message via Skype™ to nicorozog
what don´t you try the hebert´s settings for snowbirds:
0/10/10/1
FDR: 35/106 64p
hope this help....
nicorozog is offline   Reply With Quote
Old 03-15-2012, 06:10 PM   #279
nicorozog's Avatar
ey guys, 10.5 Reedy motor works simply amazing, i could get a podium in boosted class on the first race....here is the settings:
LRP SS V2: 0/10/6/3
FDR: 6,69 With 48P
20 timing
Asphalt
Nicolás Rozo
Bogotá-Colombia
Old 03-15-2012, 06:50 PM   #280
0/10/10/1
FDR: 35/106 64p
hope this help....
Tried that, 180 after 5 minutes is a little hot!!!
Old 03-19-2012, 10:52 PM   #281
Trader Rating: 20 (100%+)
any feedback with using the 12.3 x 25 in 17.5 4wd onroad applications. just want to try the other rotors besised the 12.5 stock torqe one
goots is offline   Reply With Quote
Old 04-04-2012, 07:05 PM   #282
LOSI123's Avatar
Old 04-04-2012, 07:20 PM   #283
Originally Posted by LOSI123 View Post
anyone?
heya
have been playing with the 13.5 v2 motor with boost as i need to find something to have as a backup motor, have tired spv3s, d3s, redines and the tp motor, the only one that came close to the reedy was the d3
i beleive the markings to be in real degrees of timing, at 0 the motor was slow and cold at 6 minutes, at 20 it was pretty dam good and at 45 degrees c 6 minutes and at 40 it thermaled at about 5:30 minutes and blimmin heck was it quick!
i tried 30 a few hours later and set the same times as i did at 40, but with out the heat
ed
Edwin Pibal is offline   Reply With Quote
Old 04-04-2012, 07:37 PM   #284
drs92's Avatar
Trader Rating: 36 (100%+)
Send a message via AIM to drs92
Hey guys read the whole thread and got one coming on the way since my thunder power was backordered! 17.5 going to be running it in 2wd sct though. Small clay and technical track with one straight away. Started gearing at 24/90
To change the timing on these you unscrew the back correct? Also if anyone is using it for offroad what are your esc settings...
TLR 22B
drs92 is offline   Reply With Quote
Old 04-04-2012, 07:58 PM   #285
cant help sorry, i run a tc6 now.
