Old 02-14-2012, 08:48 PM   #241
Trader Rating: 20 (100%+)
Originally Posted by Skiddins View Post
But that's the problem.
I will continue to see what settings I can change on my ESC (Black Diamond) and the motor to see if I can get any more from it.
With the Tekin, you can at least narrow the RPM start and finish to increase punch a bit.
Increasing the motor timing definitely helps with punch, but have to find the happy medium of ESC timing as well so I don't cook it.
Highest I've had the motor timing is the third notch but I'll try to go up to the 4th with a bit less on the ESC and see how it goes.
Skiddins
Ive tried everything on the RS and found where I want the motor. Smooth = not punchy. If you want the rip I suggest a different motor. But by all means the Sonic is just as competitive as anything else on the market
goots is offline   Reply With Quote
Old 02-15-2012, 06:49 PM   #242
@Art_Mighty's Avatar
Modified motors seem to have their stators and rotors in diffrent physcal positions from their stock counterparts. Using these reedy sonic rotors as a clue it appears that the mod rotors have their magnets closer to the front of the motor...
Sonic Stock Rotor 12.5 x 25.0 (Part #956)
vs.
Sonic Modified Rotor 12.5 x 25.0 (Part #958)
... because that little brass collar is spacing the rotor away from the endbell/timing assembly. What I don't get is why?
RC.A. - Tamiya Chapter (so many shinny blue parts..) O_o
Sponsored By - http://enginesbyotto.com/ & my wallet (mostly my wallet actually...)
ALL IS LOST
@Art_Mighty is offline   Reply With Quote
Old 02-16-2012, 04:25 PM   #243
AE-Reedy
vs.
Both rotors require the little brass spacer, somebody probably dropped the spacer on the stock rotor when doing the photos.
Sean Cochran is offline   Reply With Quote
Old 02-17-2012, 03:02 PM   #244
Just bought one of these in 21.5 for f1 racing. I am replacing a 21.5 Novak that I was borrowing. How will this motor compare to the Novak? Hoping for a little more rpm since the f1 doesn't need a ton or torque. Please be honest in your answers.
Any tips are always appreciated. Thanks.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 02-17-2012, 03:32 PM   #245
Maybell's Avatar
Boost or blinky?
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 02-17-2012, 03:37 PM   #246
Chaz955i's Avatar
You are correct. My stock motor has the brass spacer.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 02-17-2012, 03:54 PM   #247
Originally Posted by Maybell View Post
Boost or blinky?
Blinky. We can not use electronic boost but as much motor timing as we want. Currently running a Novak edge esc.
Serpent S120 13.5
Old 02-17-2012, 07:40 PM   #248
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
The Sonic is very good for F1
Check over at the UF1 page for setups.
F1 is alive and well in So. Cal!
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-17-2012, 07:43 PM   #249
Maybell's Avatar
I would start the motor timing at around 38-40, depending on gearing and size on track.
Old 02-18-2012, 12:42 AM   #250
Hello,
I ve a ready sonic 5.0 with SP gt 2.0 pro and i ve some cogging at low throttle in sensored mode. Nothing in sensorless
Where could be the problem ?
Manson is offline   Reply With Quote
Old 02-19-2012, 08:23 AM   #251
Originally Posted by Manson View Post
Hello,
What are your speed control settings? Too much initial punch can cause a low speed hesitation.
Serpent S120 13.5
Old 02-19-2012, 08:32 AM   #252
Ran this motor for the first time yesterday. It has more punch and more top end over the Novak I was using. Ran my fastest lap by 0.3 last night. Great motor.
It does seem to run 20 degrees hotter than the Novak. I noticed my Novak motors cool down after they have been run for a while. Will the reedy cool down as it breaks in? It didn't overheat but it got up around 150 with one spot temping at 160. The Novak ran around 130 with a hot spot of 145.
Serpent S120 13.5
Old 02-24-2012, 02:23 AM   #253
Skiddins's Avatar
Is there a particular technique for removing the bearing from the sensor unit?
I can make it move a bit, but as the access hole on the opposite side is very small I can't get anything into it to push the bearing out.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-24-2012, 03:25 AM   #254
0 boost, drrs 3. So i don t think it s my setup...
Old 02-25-2012, 05:18 PM   #255
KELVIN KHNG's Avatar
Trader Rating: 15 (100%+)
HEY GUYS
Does anybody know how many degrees of timing does the neutral mark on the reedy sonic have? I have the version without any numerical markings. Also how much timing is each marking?
KELVIN KHNG is offline   Reply With Quote
SEO by vBSEO 3.5.0
