Old 01-09-2012, 08:58 PM   #181
GreenSC10's Avatar
Originally Posted by Buckaroo View Post
What kind of 'power' are you looking for?
Although the relationship isn't always linear, the general rules of thumb are as follows:
Low timing = higher torque, lower rpm
High timing = lower torque, higher rpm
Most motors have somewhere around 28-30* of mechanical timing built into the design when the indicator is at the 0 or 'big line' reference mark, with somewhere between 4-8* for each line after that.
I believe somewhere on this thread the new scale and indicator of these motors indicate ACTUAL timing (although I may be wrong).
Edit: Found It!! (emphasis added)
Thanks for the info, I was looking for a good starting point. We have a new layout that I have not been on yet, so Im not sure on how were going to gear the touring cars. Im starting at a 4.08 fd with 30 on the timing and blinky mode for 17.5 stock touring. Depending how long the longest stretches are I may add for more rpm's or lower to get some GO. We'll see
Green FT RC8.2e
GreenSC10 is offline   Reply With Quote
Old 01-10-2012, 02:24 AM   #182
Skiddins's Avatar
Originally Posted by goldsworthy1 View Post
This might be a stupid questions guys...
but this is my first brushless motor with adjustable timing...
does each line on the can represent 10degrees of timing?
Look at post #71 & 72 on page 5 to see the two types of can.
The bigger picture (newer can) is actual timing numbers.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-10-2012, 10:48 AM   #183
frank b's Avatar
Thumbs down
I am running the new sonic 17.5 in 1/12 and I am wondering if here is a 1s rotor for the motor because I can not find it anywhere on the net.... Help please
frank b is offline   Reply With Quote
Old 01-10-2012, 11:38 AM   #184
geeunit1014's Avatar
Go for the 12.3x24.2 for 1s
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 01-10-2012, 11:41 AM   #185
AE-Reedy
There is no rotor that we designate as a 1s rotor. We offer tuning rotors.
We, the team, have just been running the motor the way it comes from the box. But if you want to try running a weaker rotor try #954, 12.3x24.2 w 7.25 shaft.
Sean Cochran is offline   Reply With Quote
Old 01-10-2012, 01:32 PM   #186
frank b's Avatar
What do you guys run as a roll out for 17.5 ? I might be off alittle and some help please I am new to 1/12 brushless racing. At my local track I am getting passed down the straight away's and I am stuck not knowing what to do next....
Old 01-10-2012, 02:08 PM   #187
AE-Reedy
Your running non-boosted?
I haven't raced that myself but would guess a rollout of 100-102mm maybe more, depends on the size of track your running. How much timing are you using in the motor?
Old 01-10-2012, 04:55 PM   #188
frank b's Avatar
Sorry we are running boost with 17.5 and the guys at the track are saying about 80 does that sound right...
Old 01-10-2012, 05:08 PM   #189
Hey Sean,
with a 1/12th scale 17.5 blinky rollout of around 100-102mm as you have suggested in your recent post (still using the standard rotor that comes in the motor), what timing setting would you recommend as a starting point? Mine is one of the newer edition Sonics with the revised timing pointer.
vafactor is offline   Reply With Quote
Old 01-10-2012, 05:18 PM   #190
AE-Reedy
Yes I guess that might be in the right vicinity. I would go with 27-30 degrees of timing for boosted. Boosted is alot more complicated obviously. What SC are you using?
Originally Posted by vafactor View Post
Hey Sean,
I would start at 40 degrees and go from there. I ran 13.5t NB last month with one of the older motors and only ran about 30-32 degrees. It was still fast but I would have liked to see what more could have done.
Old 01-10-2012, 05:25 PM   #191
Professor's Avatar
so just so i'm clear here,the can in post #72 with no numbers on it only makings is the older can yes ?????ok so if its set in the middle like the picture
at 0 is there any inbuilt timming when at 0 if so how much & each increment of timimg (+ or -) is worth how much timing ????
appreciate any feedback,thanks
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 01-10-2012, 06:27 PM   #192
frank b's Avatar
Lrp sxx stock spec and it has been updated recently .... Settings are 0-10-12 on speedo , on the infield I can stay with everyone then when I hit the straight away I get passed. I love the motor and am trying to figure out what I'm doing wrong.Temp of motor comes off at 149...
Old 01-11-2012, 11:33 AM   #193
AE-Reedy
Yes the motor in the photo is the original version of the Sonic.
Where the pointer is in the photo, middle of scale, equals 15 degrees timing.
All the way to the right and that is zero, all the way to the left and that is 30 degrees. Each mark equals approximately 4 degrees timing.
Old 01-11-2012, 11:39 AM   #194
AE-Reedy
Ok let me run down the list so I'm clear.
SXX-SS with v4.4sw 0/10/12/0
Reedy Sonic 17.5t with 80mm rollout
What timing on the motor?
Everything you have mentioned so far seems ok.
I'm guessing the timing in the motor is low, but I need to know before I can go further.
Also are you confident that you aren't getting cheated by others you are racing against? If you are truly getting pulled that bad on the straight that doesn't sound right, alittle difference due to not having a good set up is reasonable. But if someone is really pulling you I would be inquireing about what they are doing.
Old 01-11-2012, 01:10 PM   #195
tommy911t's Avatar
Trader Rating: 50 (100%+)
Default 17.5
sorry, wrong thread!
tommy911t is offline   Reply With Quote
