Old 01-07-2012, 03:50 AM   #166
Trader Rating: 20 (100%+)
whats the stock rotor that comes with the 17.5?
goots is offline   Reply With Quote
Old 01-07-2012, 04:08 PM   #167
Rick Hohwart's Avatar
http://reedypower.com/products/details/956/
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 01-07-2012, 05:39 PM   #168
stiltskin's Avatar
Trader Rating: 102 (100%+)
Odd question for you Rick. I have two Sonic 17.5 motors. First one I bought has limited timing adjustment and runs awesome. I bought the V2 motor for the additional timing option. Problem with this motor is that it always smells like it's been overheated. Comes off the track between 140 and 160 but smells like it melted down. Runs good but not as quick as the other motor.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-07-2012, 07:20 PM   #169
Trader Rating: 21 (100%+)
I have a new version and noted it smelled overheated also. Usually 140-155 range to.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 01-07-2012, 08:14 PM   #170
maxepower's Avatar
Exclamation Rebuildable?
So are these motors rebuildable like the Novak Ballistic. In other words if I want to change the stator can I do it myself or do I have to have it done at Associated?
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-07-2012, 08:40 PM   #171
It is important to note that the latest version has a modified end plate with a repositioned pointer indicator. If you are running the same timing (indicator relative to the can screw) you are running too much timing. The new version should be set around 40-45 degrees.
The stator can be changed by yourself but we do not offer them separately yet.
www.reedypower.com
Old 01-07-2012, 09:02 PM   #172
Timing is set at 40.
Thanks to pops
Old 01-08-2012, 06:09 AM   #173
stiltskin's Avatar
Thanks for the response Rick. I am aware of the added timing. I even swapped the plastic end cap from the old to the new to see where the pointer ends at full timing. I started at 40 degrees just like my current motor and gradually increased timing while checking temps. The motor never got hot and smelled odd from the very first run. I assumed that it was some kind of factory oil/lubricant that burns off after use. I'm very happy with my original motor. Several others have bought them since I started running it. Just curious why the second one smells so bad. I'm going to clean the motor and see if it goes away. Otherwise it will become a practice/backup motor. See you at the birds.
Tony Rumple
Old 01-08-2012, 04:32 PM   #174
GreenSC10's Avatar
I'm a little confused, the indicator 0-40 right to left, which end creates the most power 40 or 0?
Green FT RC8.2e
GreenSC10 is offline   Reply With Quote
Old 01-08-2012, 05:14 PM   #175
Buckaroo's Avatar
What kind of 'power' are you looking for?
Although the relationship isn't always linear, the general rules of thumb are as follows:
Low timing = higher torque, lower rpm
High timing = lower torque, higher rpm
Most motors have somewhere around 28-30* of mechanical timing built into the design when the indicator is at the 0 or 'big line' reference mark, with somewhere between 4-8* for each line after that.
I believe somewhere on this thread the new scale and indicator of these motors indicate ACTUAL timing (although I may be wrong).
Edit: Found It!! (emphasis added)
Originally Posted by Sean Cochran View Post
Just so everyone is aware the new scale is supposed to be ACTUAL degrees of timing. So if you are on 20 that means you have 20 degrees of timing in the motor.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 01-09-2012, 04:10 PM   #176
so it already comes with the high torque rotor.. Is there anyway to get more punch out of the motor?
Old 01-09-2012, 04:25 PM   #177
geeunit1014's Avatar
What vehicle/setup are you running? The setup I posted last page for my touring car has all the rip in the world.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 01-09-2012, 04:32 PM   #178
This might be a stupid questions guys...
but this is my first brushless motor with adjustable timing...
does each line on the can represent 10degrees of timing?
|Sakura Zero S Tekin RS Reedy Sonic 21.5T|
goldsworthy1 is offline   Reply With Quote
Old 01-09-2012, 04:43 PM   #179
17.5 boost TC. I tried lots of fdr's, from 5.6 - 6.3 just wished it was a little more punchy. My last thought would be going to a torque rotor but its been cleared that it already comes with it. Looks like ill just drive the way it is.
Old 01-09-2012, 06:09 PM   #180
What esc/settings are you using?
Mike Gee
