Old 12-22-2011, 06:08 AM   #136
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Sean Cochran View Post
There was a batch of motors that the timing has a limited adjustment just like what you are describing. We have since asked for that change to be undone.
If you need to get more timing you will have to take apart the sensor assembly and then you will have to file the legs on the sensor so that it can spin more. It's difficult to explain with out pictures, once you take it apart you might understand what I mean.
Originally Posted by Jamison R View Post
Does this make legal motor "illegal" for stock racing, as it will be modified from stock form??????
good question considering the above statement.
further, when are the revised motors hitting shelves? i would have thought the ones with the new can labeling would also have the unlimited timing modification. i have not had my motor open yet, but it rotates plenty and has the old scale.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-22-2011, 08:06 AM   #137
Rick Hohwart's Avatar
The motor was submitted for approval with the ability to achieve the maximum timing (center of the screw). The first production motors allowed this. The latest motors now allow this maximum timing setting that the motor was submitted with (although the scale is altered).
You could argue that you are altering the motor to increase timing but in reality you are altering it to achieve the same timing that the motor was approved with.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 12-22-2011, 10:44 AM   #138
AE-Reedy
I recently bought a new reedy sonic. It appears to be a newer version. It has the numbers as shown in a previous pic. My question is. Are these made differently? There is no way the timing mark will go all the way to the screw.
With the new timing scale you would never turn this motor to the screw.
You should never go above the end of the scale. I would recommend starting at 40 for no timing and adjust from there. If you are running in a boosted class or modified I would recommend starting at 20.
AGAIN DO NOT RUN THE NEW VERSION MOTORS AT THE SCREW!
Sean Cochran is offline   Reply With Quote
Old 12-22-2011, 11:06 AM   #139
wingracer's Avatar
Trader Rating: 23 (100%+)
I agree with you theoretically but you know how rules makers are. I would be hesitant to run a modified one at the birds without getting the ok from them.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 12-22-2011, 11:16 AM   #140
seaball's Avatar
sean - we should infer from this that the sensor has more timing in it than earlier versions, then? i think i had it backwards when i drew my last conclusion between the two versions ...
Old 12-22-2011, 01:10 PM   #141
AE-Reedy
The sensor is exactly the same but we had the pointer moved on the plastic cap so the scale could be repositioned on the motor.
Note position of the timing pointer in the photo.
Old 12-22-2011, 01:36 PM   #142
seaball's Avatar
ah, right on! i'd have never caught that. sweet. the new scale makes things much easier to boot.
Old 12-22-2011, 01:41 PM   #143
AE-Reedy
That was the reason for re-doing the scale. After non-boost became the main type of racing the previous scale was inadequate. It just didn't seem right to tell some one "Just turn the timing up to the screw." It's much better to say "Run the timing at 40 for blinky, etc."
Just so everyone is aware the new scale is supposed to be ACTUAL degrees of timing. So if you are on 20 that means you have 20 degrees of timing in the motor.
Old 12-22-2011, 02:32 PM   #144
stiltskin's Avatar
Trader Rating: 102 (100%+)
That's crazy talk.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-22-2011, 02:32 PM   #145
Scott B's Avatar
Trader Rating: 43 (100%+)
Sean or Rick,
What FDR would you recommend to start with for a 4.5 and 5.0 at NorCal hobbies home of the Reedy race??
Thanks,
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 12-22-2011, 04:17 PM   #146
if there is chipotle involved I think I have an answer !! If I am not mistaken, rick ran a 5.0 with 20 degree timing at a 8.2 last year
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 12-22-2011, 04:19 PM   #147
greywolf74's Avatar
Trader Rating: 15 (100%+)
nice
greywolf74 is offline   Reply With Quote
Old 12-22-2011, 04:27 PM   #148
Scott B's Avatar
LOL, I might have some Burrito Bucks for you guys at next years Reedy!!
Thanks,
Old 12-27-2011, 12:19 PM   #149
Professor's Avatar
Default reedy sonic
can someone tell me who sells the reedy sonic"s in the us please
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 12-28-2011, 04:23 AM   #150
here is one
http://www.amainhobbies.com/index.ph...&filter_mfr=13
and another
http://www.nexusracing.com/index.php?cPath=140_243_455
and also
http://www.stormerhobbies.com/cgi-bi...owt=on&omode=0
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
