Old 12-13-2012, 03:48 PM   #91
AdrianM's Avatar
Best and strongest fans....
http://www.youtube.com/embed/S2nYtZyyfHA
Adrian Martinez
Old 12-13-2012, 03:51 PM   #92
UrabusDenis's Avatar
A bit off topic, but related to cooling- anyone tried using thermal paste between the motor and heatsink?
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
RW mods - www.rw-mods.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 01-10-2013, 07:54 AM   #93
After testing with lots of cooling fans, the top two that I have tested are:
*Yeah Racing 30x30mm
*LRP Esc 25x25mm
Those who are using Hobbywing and 3Racing fans, do yourself a favor, it is only dead weight, it does not cool anything.
I'll be receiving in a few days the Seis Fans and Yeah Racing's 25x25 to see how they match up against each other.
I'm testing these fans using the scale method (Like Yeah Racing's videos) and an anemometer.
Other fans that have been tested:
-Muchmoore High RPM fan 30x30
-R1 Wurkz 40mm fan
Serpenteer is offline   Reply With Quote
Old 01-10-2013, 08:01 AM   #94
Jerry P's Avatar
Trader Rating: 44 (100%+)
how are you testing? are you using a flow test or just what you feel moves more air? You should give http://www.sidepieceracing.com/products/seis/ a try. I know I've seen a 30 degree change when running outside. Back to back testing has been done on a 17.5 motor running 6 minutes on an asphalt track.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 01-10-2013, 08:09 AM   #95
I'll be receiving the Seis fans in a few days. I'll see if the fans like up the hype, which I hope so.
I'm using an anemometer and placing the fan back-to-back to it. Also using a scale weight and placing the fan against to see what reading it gives. I don't have the concrete numbers here, but if I'm not mistaken, the Hobbywing fans don't even give a reading or gave a 0.2-0.3g compared to LRP Esc fan (from an old TC sphere) gives a 2.6-2.7g reading.
Old 01-10-2013, 08:32 AM   #96
Bishop's Avatar
The Yeah Racing 'is' very good, it pushes a lot of air for something so small, taped to a chassis blowing onto the motor makes a huge difference in temps.
Downsides, is they are just a little fragile, they crack easy, and they do seem to like the suggested 'run in' listed in the instructions.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is online now   Reply With Quote
Old 01-10-2013, 06:47 PM   #97
Adam B's Avatar
Default FRP fan
I have had very good luck with this fan.
http://shop.franchiseracingproducts....m?categoryId=3
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 01-10-2013, 08:33 PM   #98
hanulec's Avatar
Trader Rating: 23 (100%+)
fragile ... yikes!
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-10-2013, 10:06 PM   #99
BBJ
BBJ's Avatar
Interesting reading...
Something that hasn't been suggested when using 5 volt fans. Try using a resistor to drop the voltage down from the source. The value of the resistor based on the source voltage and fan current draw. By doing so you aren't overloading the fan motor. Sure, you won't move as much air, but the life of the fan would definately be extended. I guess it's a trade-off between component life and performance.
BBJ is offline   Reply With Quote
Old 01-11-2013, 02:31 AM   #100
Skiddins's Avatar
If people just buy a fan with a wide enough input voltage range then 6V won't matter.
Normally the fans will get damaged before the electronics gets a chance to fry.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-11-2013, 02:44 AM   #101
The Crazy fan (40mm) form rcmushroom is really good too, i used the tornado 30mm before but i like the crazyfan better, plus its half the price of the yeah racing
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 01-11-2013, 04:55 AM   #102
Adam B's Avatar
Not sure if you have to follow ROAR rules, but that is to big to be ROAR legal.
Old 01-11-2013, 06:17 AM   #103
Ah there are no rules regarding fan sizes in sweden
Old 01-11-2013, 10:54 AM   #104
oldrcr's Avatar
Trader Rating: 43 (100%+)
I'd say that may be one of many good reasons to move there.
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 01-11-2013, 11:18 AM   #105
Adam, have you tested these FRP fans against the Yeah Racing ones back to back??
SEO by vBSEO 3.5.0
