Old 09-11-2012, 12:13 AM   #61
Bishop's Avatar
Originally Posted by theatriks View Post
All it says on it is 12v 0.10A
Most cooling fans for computers are actually fairly low CFM, as in reality they are rated for low noise, and super long life span.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-11-2012, 01:40 AM   #62
Skiddins's Avatar
Originally Posted by hanulec View Post
Over 4cfm at 6v.
Fans must be run to off receiver (or anything below 6.7v). Wiring to the receiver gives you a bunch of options when swapping/rewiring electronics.
Do they make a 40mm version? as 4cfm while high for a small fan, I prefer to use a heatsink with a larger 40mm fan.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-14-2012, 12:32 PM   #63
theatriks's Avatar
So got my 3 SEIS fans today only took 4 days gotta love that!.....anyways on first appereance they look strong a lot thicker then your average fan but still compact enough to put it where you want it.....wired her up and plugged her in and i gotta say its no joke these babies move alot of air ....great purchase!
theatriks is offline   Reply With Quote
Old 09-14-2012, 01:14 PM   #64
hanulec's Avatar
Trader Rating: 23 (100%+)
Thanks for the review.
Unlike other fans they don't break when you look at them wrong ...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-14-2012, 01:24 PM   #65
theatriks's Avatar
No problem ....just outta curiosity did those geisha fans move more air then the SEIS
Old 09-15-2012, 05:49 AM   #66
Mr RCTech's Avatar
STOP: fanning your motors and just get one of these:
RC motor cooler/freezer aka The Frankencooler that I make
Mr RCTech is offline   Reply With Quote
Old 09-15-2012, 06:08 AM   #67
UrabusDenis's Avatar
I've had really bad luck with fans recently, 2 pro RC fast fans gave up this season. I run a two fan configuration, since it is really neccesary in our 10,5T boosted, almost everyone runs two fans. Motor temperatue is a critical issue around here. One was a Yeah Racing tornado fan and was really satisfied how it cooled, but it gave up, the second one is a fan bought from a local PC shop which works but not nearly as fast as the professional ones. I currently have two PC fans which is okay at the technical track I raced last time, but it won't work on my fast local track. So, I'm looking for the most durable high speed fan? I'm looking to buy LRP fans, simply because LRP is a strong name.
BTW I connect my fans to the ESC
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
RW mods - www.rw-mods.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 09-15-2012, 06:51 AM   #68
theatriks's Avatar
140 bucks ....i will stick with the 9 dollar SEIS fan
Old 09-15-2012, 08:42 AM   #69
Freezing your motors is also against ROAR rules too. So I wouldnt be trying that at anything other then a club race.
Goto your electronic shop, and you can buy the Peltier CPU cooler really cheap. I paid $28, and if I forgot about it I had ice on my motor.
Shawn
Shawn68z is offline   Reply With Quote
Old 09-15-2012, 08:42 AM   #70
Skiddins's Avatar
http://www.nmbtc.com/fans/part-numbe...L-01W-B50/4966
That's the highest airflow 40mm fan I have yet found (still looking for stuff that's faster) It is 20mm deep and is a lot faster than the standard LRP fan.
8.1CFM
It's 5V so it needs to run off the receiver
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-15-2012, 09:10 AM   #71
theatriks's Avatar
8.1CFM
Skiddins
8.1 CFM ...NICE!
Old 09-15-2012, 09:39 AM   #72
Has anyone tried the R1 Wurks fans?
http://www.r1wurks.com/category.php?id_category=5
Shawn
Old 09-15-2012, 10:11 AM   #73
theatriks's Avatar
Shawn
I had 3 of them ...the fans work good but those mounts are no good ...all three mounts broke on me....not worth the 30 dollar pricetag in my opinion
Old 09-15-2012, 03:57 PM   #74
Skiddins's Avatar
There is also the problem that the fan only cools one side of the motor.
I always use a heatsink with a fan to try and even out where the cooling takes place.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-15-2012, 04:39 PM   #75
theatriks's Avatar
I got 2 fans on my motor one in front and one in back lol maybe adding a heat sink up top would help even more but will look a little bulky
