Team AutoTrueCut Tire Truer >
Old 10-04-2004, 07:49 PM
JohnMatrix's Avatar
Default Team AutoTrueCut Tire Truer
In the description it says it can resurface rubber tires.
Now I got this cause I’m moving in to mod in a month or three so its not a total lose, but it doesn’t have directions on how to true rubber tires.
Any help?
http://integy.automated-shops.com/cg...19104470570.2b
JohnMatrix is offline
Old 10-05-2004, 04:18 AM
robk's Avatar
Trader Rating: 22 (100%+)
The only thing i have seen guys do is use a truer to remove the mold line on the center of the tire. When a rubber tire goes, it is usually because of a chemical change due to heat cycles.
robk is offline
