Old 08-04-2014, 11:37 AM   #346
spacendeman's Avatar
Send a message via MSN to spacendeman
Here would also be appriciated I think?
So that people can see the answers?
Nice body on your F110!
I made an Ferrari F60 for mine :-)
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 08-04-2014, 06:53 PM   #347
DIRTMONKEY's Avatar
Thanks for the kind words on my F110 MERC BODY
As requested
Originally Posted by Nick Heldens View Post
Well let me ask a silly question:
- which tools do I have to buy to put the F110 together and maintain it?
Partnumbers would be a big help ( 1.5, 2 , 2.5, 3, mm hexes 5.5, 7 mm socket pretty much the standard tools I use the EXCEED brand tools )
Thanks.
Furthermore:
Do you guys use tire warmers on rubber tires on asphalt? ( DEFINITELY )
For how long a time and at what temp? ( 45 TO 50 degrees 10 to 15 before race starts )
Which tire warmer best to use? For exemple the one from GT Power? ( that is the one I use great little unit )
Rapping the tires in tissuepaper before putting the warmers on them? ( No need with the wrap style the GT POWER unit uses )
Which tire additives best to use on Ride rubbertires on asphalt? ( GRIPPER V3 is what I use )
Which is the ETS mandatory tire additive? ( UNSURE what europe uses )
Which percentage of the tire surface best to put tire addivite on?( 100% rear, outer 50% front )
Hope this helps also check out the build before going ahead will give some handy hints to make job easier
http://www.rcformula1.com.au/images/...f110_build.pdf
DMP RC ART WURX
Thanks to - SWORKZ Aust / Ryper Hobbies - SWORKz S350 EVO II Limited Edition / SWorkz S350T Pro Competition - AKA Aust - INTENSE RC HOBBIES - RB-BARMAH RC - TEAM UPGRADE RC -PLAIG BEARINGS - WALTER R/C Hobby - SERPENT Spyder SCT SRX-2 -SERPENT Spyder RM - SERPENT Spyder ST - SERPENT F110
Last edited by DIRTMONKEY; 08-04-2014 at 08:27 PM. Reason: reposted the link as didn't work
DIRTMONKEY is offline   Reply With Quote
Old 11-08-2014, 07:17 PM   #348
Hey Guys,
Is anyone running their shorty lipo all the way back with the esc and receiver in front of the lipo? Just wondering if it makes a large difference in rear traction without sacrificing too much steering. Thanks in advance.
Andrew.
AKRacing is offline   Reply With Quote
Old 11-15-2014, 07:33 AM   #349
Hi,
Sorry for a late post.
But you defenetly are going to experience some difference with the weight.
I think with the Ride tyres you don't want to drive with the lipo all the way in the back.
I drive the lipo in the middel of the car. It is good for me. Allthough I can use some weight in the front with rubber tyres.
Currently:
Old 11-15-2014, 05:33 PM   #350
Thanks for the info space man. I saw a picture of an F110 at an ETS race and saw the shorty all the way back and was curious if anyone had a good experience with the layout. I think I'll stick with the shorty in the middle.
AK
Old 11-16-2014, 03:11 AM   #351
Hi AK,
It is possible to run the lipo in the rear part of the layout.
I think the person did this because of low traction.
But the more weight you put to the back to create more rear traction the less steering you get because the weight moves to the rear. So then you shall have to setup the front for more steering.
I find that I rather have understeer then oversteer.
Regards,
Tim
Currently:
Old 12-22-2014, 02:36 AM   #352
Not much going on in this thread, so I thought I come up with a noob question.
Do I understand it right, that camber is only adjusted with the pivot balls and not with the trackrods?
So the trackrods are only used to adjust caster?
Thank´s in advance!
TOP Rebel 12 - Hobbywing XR10 Pro Stock Spec - GM Racing 10.5 - nVision - Futaba
TLR 22 4.0 - GM Racing - Graupner - Futaba
M.Boos is offline   Reply With Quote
Old 12-22-2014, 01:16 PM   #353
Madulla's Avatar
Nope turnbuckle links for both camber and castor. You could use the pivot ball to adjust camber, but the camber link is right on top and easier to adjust.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 12-23-2014, 01:56 AM   #354
Hey guys, was reading the recent ETS race report where David Erhbar came 3rd overall. The report said he was using a prototype F110. Anyone know anything about a potential new Serpent F1 car?
Old 12-24-2014, 08:18 PM   #355
dan_vector's Avatar
Trader Rating: 25 (100%+)
Yeah I read that too! I'd be happy enough just to see Erhbar's setup from the ETS! The team drivers don't tend to post F110 setups for some reason?
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-25-2014, 12:39 AM   #356
bd581's Avatar
Seen the price of the F110 at walter rc?
Very cheap at the moment, that usually means something is in the works
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is online now   Reply With Quote
Old 12-25-2014, 01:29 AM   #357
ta04evah's Avatar
Hopefully they'll fix the problem of the lower steering/suspension blocks moving after hitting something, and stopping the upper "y" pieces from breaking, that's what annoyed me the most when I had one.
If they can address & fix those problems alone, then they won't have to do too much to the rest of the car to make it any better.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 12-25-2014, 10:13 AM   #358
Madulla's Avatar
I find that if you flip around the ride height adjusters so the "closed" end rests against the suspension blocks it helps to prevent them from moving. It's the opposite of the instructions and 12 scales.
What I find odd is that the metal replacement bulkhead is now discontinued and nothing to replace it?? It was the weak part of the car. It was the only hop up that the car needs. It should have been an original part.
hobbywingdirect.com
Old 01-03-2015, 03:23 PM   #359
Adam B's Avatar
I couldn't find an article mentioning a prototype F110, only thing I read was that it was his 2nd time running the car. Pictures I seen of his car didn't look special at all. So who knows what is coming and when.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 01-04-2015, 12:06 AM   #360
dan_vector's Avatar
Here. http://teamserpent.com/blog/2014/12/...-formel-class/
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13562 08-15-2017 09:24 PM
1/10 F1 EP lovers joeblue29 Malaysian R/C Racers 128 02-06-2011 11:06 PM
Serpent 1/10 Impact M2 looking for info Nova F1 Racer Nitro On-Road 8 05-14-2004 10:23 AM
