Old 01-06-2014, 07:55 PM   #271
Evo 13's Avatar
Originally Posted by Bigz84 View Post
i don't think you will get these cars up to 110mph, not sure though?? but you can put in a 540 sized can, 4.5 turn motor, and put in a esc w/ the availability to put in a lot of timing and boost.
i run a 4.5 turn motor, timed and boosted, in a touring car and the car flies down a straight away. gearing has a lot to do w/ top speed. make sure you put a fan on the esc and motor to keep things cool.
Thank you
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 01-07-2014, 02:06 AM   #272
AllenCheung's Avatar
The problem with the 'scale looks' is that the real F1 cars change constantly (look at the 103 vs. the 104). I think it would be a good idea if there was some standard open wheel class that was more stable.
AllenCheung is offline   Reply With Quote
Old 01-07-2014, 02:07 AM   #273
People are always going to tinker and try to improve things. That is part of all forms of racing. The only way to prevent that is to have some sort of spec chassis but that is just as bad because people get tired of the restrictions and lack of diversity and stop racing due to that. Either way you will always have cycles of growth and decline. It is a natural thing.
Old 01-07-2014, 11:05 AM   #274
that Serpent is an interesting car if you want to tune it. Replace the front wheelaxle by the S100/120 one, put a Pan car rear axle/hubs and you got a very fast F1 with Pan car Tires or a WGT with the right body on it.
Gurneyflap is offline   Reply With Quote
Old 01-09-2014, 02:06 AM   #275
Old 01-09-2014, 02:07 AM   #276
Old 01-09-2014, 02:08 AM   #277
cool, ilike this kit
Old 01-09-2014, 02:21 AM   #278
M7H
M7H's Avatar
Originally Posted by Evo 13 View Post
Thanks guys, Now I'm a speed demon by nature, What kind of MPH is this F110 capable of?
Originally Posted by ErikJan View Post
110mph should be possible
What motor should I get to make 110mph possible?
I think ErikJan was joking....
Serpent
M7H is offline   Reply With Quote
Old 01-09-2014, 02:48 AM   #279
ErikJan's Avatar
Really? . Let's make it 110km/h to be more realistic.
ErikJan is offline   Reply With Quote
Old 01-14-2014, 03:46 AM   #280
Trader Rating: 25 (100%+)
Guys, what damping oil are most of you using on the front spring pins on asphalt?
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-14-2014, 04:39 AM   #281
I tried my car last weekend, asphalt, ets rules, and i used 400 cts in the front kingpin, 30.000cys in the roll damper and 800 cts (4 holes) in the shock. car was dialed, great perfomance.
jimjav is offline   Reply With Quote
Old 01-14-2014, 07:55 AM   #282
Thumbs up
Thanks for the info. Will give it a go.
Old 01-17-2014, 06:41 PM   #283
Trader Rating: 14 (94%+)
I'm suffering from torque steer. It's quite severe. Front wheels free wheel fine. Ball diff is normal. The side pod connectors are set loose so that they move freely against the pivot balls.
I tightened the connectors just to try. It's better but the torque steer was still there. I did that because the pod was moving left and right a little bit. It removed the play but I guess it creates binding.
It's definitely because of tweak. When I lift the front to check droops in the front, Left always lifts first no matter how much I screw in the right side set screw.
Why are there two threads for this car anyway? Do we use this one or the other?
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 01-17-2014, 11:29 PM   #284
DIRTMONKEY's Avatar
This site is AMERICAN and the other is AUSTRALIAN both will give you answers. If in AUSTRALIA ask there as it gives you answers for AUSTRALIAN conditions such as temps and tyres as the US has different track surfaces temps just makes it easier to relate
DMP RC ART WURX
Thanks to - SWORKZ Aust / Ryper Hobbies - SWORKz S350 EVO II Limited Edition / SWorkz S350T Pro Competition - AKA Aust - INTENSE RC HOBBIES - RB-BARMAH RC - TEAM UPGRADE RC -PLAIG BEARINGS - WALTER R/C Hobby - SERPENT Spyder SCT SRX-2 -SERPENT Spyder RM - SERPENT Spyder ST - SERPENT F110
DIRTMONKEY is offline   Reply With Quote
Old 01-20-2014, 05:46 AM   #285
I don't know if you have the same thing but when I asked around, I was told that I can't just gun it because it will torque steer. Is your car same? I managed to get TQ and 1st in final today in club race but I had to accelerate slowly and put -100% expo on throttle to make it tamed. Thinking of solution in bed, I think too soft dampening or spring in center can cause that. Please advise.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13341 Yesterday 06:56 PM
1/10 F1 EP lovers joeblue29 Malaysian R/C Racers 128 02-06-2011 11:06 PM
Serpent 1/10 Impact M2 looking for info Nova F1 Racer Nitro On-Road 8 05-14-2004 10:23 AM
