Best 13.5t Motor?
Best 13.5t Motor?
Already got myself a speedpassion 13.5t in my Mi4 with a hobbywing xtreme stock. Have now got an xray t3 11 on order with another xtreme esc.
Should I stick with the speedpassion or is there something quicker out there? Was looking at the GM or Nosram range.
The SpeedPassion is great I love that the cables are connected to the back of the motor, then there's space for a fan without resoldering the cables.
Of course there may be faster stuff out there, but the differences will be small.
By the way, you don't have the best ESC on the market, so you can start there if you REALLY want power
only just got the X12 and it seems wicked fast, but still trying to find the right settings to keep temps down
Also, nothing wrong with Extreme stock, thats what I am using
What makes the ESC the part in the chain that effects power output the most? I would assume that the motor would be the biggest "difference maker".
As far as spec or "non-boost" goes, the motor is most likely more important than the ESC. Once you allow boost, then the ESC matters more than the motor, since you can tweak the ESC to work around limitations in the motor.
