Old 10-03-2004, 06:47 AM   #16
thanks joeB u made my decision easy
Aadolf is offline   Reply With Quote
Old 10-03-2004, 01:03 PM   #17
Originally posted by SpeediePHATT
I would just buy the standard cheap pins and polish them yourself. I chuck them up in my cordless drill and use 200 grit sandpaper to polish them.
thats a really good idea i think i will go to that
but should the pin be a little snug in both the arm and the block? or should it be loose so the arm will go up and down with out any resistance and same for the block?
kh15 is offline   Reply With Quote
Old 10-03-2004, 01:06 PM   #18
Speedie's Avatar
It should be loose in the arm. The block doesnt matter because it doesnt pivoit in there. What I do is I run the set screw all the way into the hole and take it back out and run a drill bit the size of the pins through it to clean it out. There not loose after that but its easier to work on when it pushes out easier.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 10-03-2004, 02:41 PM   #19
yea i used some 400grit paper to get all the black of the pins and then i used the same 400 only wet to get them super smooth i havent got my arms yet from tower but if they dont easly slide in i'm gonna a drill bit like 1/64th bigger than the pin to drill it out
thanks for the addvice
My 18R...just broke it...DOH!! losifiend Micro and Mini Scales 4 05-03-2008 07:40 AM
You know you're broke when... JVT MTX3 Chat Lounge 33 11-15-2007 11:17 AM
Are the Mayhem Arms Stronger Than the Turmoil Arms? Chase Electric Off-Road 1 04-09-2007 10:34 AM
BROKE DX2 derricklong38 Electric Off-Road 2 01-04-2007 08:53 PM
double header: short arms vs. long arms, and fact vs. hype seaball Electric On-Road 100 08-01-2005 11:49 PM
SEO by vBSEO 3.5.0
