Old 05-30-2011, 07:10 PM   #16
RsageD's Avatar
Originally Posted by YZFAndy View Post
By reducing timing you will have a less rpms but should have more torque and overall efficiency is increased. Overall power is reduced but sometimes you can back timing down and not see any lose. I would start at minimum timing and work your way up. Generally by increasing timing you find a point where the motor wont make any more power but heat start to rise suddenly.
ok ok. thanks. Will do that for now.
RsageD is offline   Reply With Quote
Gear Ratio help nhodd Electric Off-Road 13 04-03-2009 03:59 PM
SEO by vBSEO 3.5.0
