Old 09-30-2004, 07:30 PM   #1
Default Takeoff tires and inserts
Is there a better insert to run with takeoff 27s (on carpet) than the ones that come with them? Someone also told me to try mounting them on 26mm wheels - I guess to reduce the air gap. Has anyone tried this, if so do they run any better?
dway100 is offline   Reply With Quote
Old 09-30-2004, 07:35 PM   #2
Joel Lagace's Avatar
At our club takeoff tires dominate the rubber class. We typically use HPI inserts. BLUE,GREEN,Reds are the norm. they fit nicely.
"Without Rules its just Backyard Bashing!"
Joel Lagace is offline   Reply With Quote
Old 09-30-2004, 08:11 PM   #3
AdrianM's Avatar
Increasing the air gap is what usually makes them faster. We have done a lot of testing and the stock medium TakeOff insert is best unless you have no grip at all. Then you run a firm foam insert. Thats what they do in the UK. We have tried everything and keep going back to the stock insert.
Adrian Martinez
Old 09-30-2004, 08:16 PM   #4
ChadCapece's Avatar
26mm really reduced the wear on the tires and allows you to run less camber. The tire contact patch increases and the insert is less prone to get pushed out and crease on the inside line of the tire.
ChadCapece is offline   Reply With Quote
Old 10-01-2004, 03:07 AM   #5
stinkypop's Avatar
In the packaging of the Take Off Tires there is a piece of paper saying:
1. In high speed track, use harder insert and adjust the suspension little softer.
2.In technical track, use softer insert and adjust the suspension little firmer.
3.If you experience your car flipping, adjust the damper stroke longer.
* Very soft inserts may not take out all ability of the "CS" tires.
From your experience do these suggestions work?
I'm running CS27's on Ashphalt , do the princables you are suggesting for carpet also apply for Ashphalt?
This might be getting of track, but do you have a favourite traction addative that you use on these tires?
stinkypop is offline   Reply With Quote
Old 10-01-2004, 03:35 AM   #6
Eirik's Avatar
On carpet there is only one insert that is good enough IMO and that is the Orion/JB Light weight Indoor inserts, Partnr: 70602, JB Foam Insert, JB32 (Blue/Hard)
This is what we use in Europe all the time and it's much faster than "standard" outdoor inserts like the stock ones and Hpi's etc.
They are also available from Peak.....
Mounting them on 26mm wheels makes the car much more stable, but laptimes might be slower so pay attention to that! However the car is easier to drive especially if traction is low...
Try'em out, I am sure you will like them allot!!
Eirik is offline   Reply With Quote
takeoff cs-27 & Cs22 tires alpha R/C Items: For Sale/Trade 7 01-01-2008 03:52 PM
TakeOff & Hot lap tires and wheels crazymechmow R/C Items: For Sale/Trade 22 05-28-2006 08:33 AM
Used TakeOff 27 Pre-Mount Tires (many sets) MClinton R/C Items: For Sale/Trade 2 02-22-2005 07:57 AM
NIP TakeOff Tires (CS22&27) - 3 sets RcMonk R/C Items: For Sale/Trade 9 11-29-2004 06:33 PM
TakeOff Tires STLNLST Electric On-Road 2 01-03-2004 11:32 PM
SEO by vBSEO 3.5.0
