Old 05-19-2011, 10:18 PM   #1
Artriel's Avatar
Default Suggestions for ESC and Motor specs/combo for drifting and a little racing????
Does anyone have a suggestions as to how many kv or turns the motor should have for amateur racing on road (tar) and occasional drifting (Associated TC5R)? Been trying to figure a brand that has good value as well as performance (hobbywing anyone?). I don't want to spend an absolute fortune although im partial to Castle Creations.
Artriel is offline   Reply With Quote
Old 05-19-2011, 10:49 PM   #2
macavant's Avatar
Trader Rating: 57 (100%+)
check this out: http://www.speedpassion.net/us/produ...128022DR&c=CMB
I have the F1 version in my F104W and it works well. No cogging for a sensor-less BL motor. Can't beat the price IMO.
likes the oldskool RC action...
macavant is offline   Reply With Quote
Old 05-20-2011, 08:29 PM   #3
The Hobbywing's are every bit as good as the castle, and much cheaper.
35A/9T Ezrun combo is a cheap starter package (unsensored), quite fast, good for drifting. Very reliable.
or Xerun if you spend more $$ & want sensored. Pretty much the same as some Speed Passion kits.
Unfortunately, they are too many fakes around.
1101 is offline   Reply With Quote
Old 05-21-2011, 04:48 AM   #4
wollow86's Avatar
I use a Novak havoc stock spec esc with a 10.5 ss pro bushless for my basher/drifter. Local club have let me run it in their stock class a couple of times as well, but if you want to be safe go a 17.5 depending on what your local club runs as stock, you can just gear it to be competitive.
If you go for a stock spec esc or "blinky", it will be cheap. My Novak was $150 on www.amainhobbies.com
They also the the speed passion cirtix stock club race for $99.
Both are a sensored setup, so will be smooth for drift.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
SEO by vBSEO 3.5.0
