Old 09-28-2004, 09:52 PM   #1
Default Issues with Lynx 3d and GT7 combo
Setting up my first elec car (TC3).
I'm having trouble getting the GT7 to nuetral using the Lynx 3d. I'm getting alot of coasting at nuetral trottle position. I've gone through every program on the ESC. I've also adj the EPA and T_Trim to no avail. I can get the car to sit still in nuet however i lose full throttle. I've also noticed that i'm not able to get hard braking... the car coast to a stop.
This makes me wonder is this just the nature of the beat with Electrics?
Advice appreciated, thnx
DirtKite is offline   Reply With Quote
Old 09-29-2004, 06:45 AM   #2
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Well I've got it all working fine in my Evo IV. I initially had problems with glitching, but that was all sorted after a little while. The GT7 just needed to be rotated 90 degrees and then the glitching stopped. I've never heard of something like that happen, but I did have a problem with the Lynx 3D once when I I needed to recalibrate the pots. Here's an attachment of what you need to do to recalibrate it. I don't know if that will fix the problem, but hopefully it will!!!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 09-29-2004, 10:20 AM   #3
Charlie's Avatar
You may not have your ESC setup correctly. You have to do the One Touch Setup on the ESC so it takes your radio's output and works. It involves button pushing and moving the trigger. If you haven't done that yet, check out the manual and go through the setup. Should work fine.
Make sure your radio's ATL is set correctly so that you full range of throttle. You can check your throttle channel output with a Servo if needed.
Email us if you have any further questions, we could have gotten back to you early this morning.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 09-29-2004, 10:00 PM   #4
Default missing data
F. Alonso,
the attachement is missing some key data elements as it refers to pictures or drawings in parts. do you have those or can you tell me how to get this info? I've looked on Hitech site and couldn't find it there.
wtb: mamba max combo or any brushless esc:motor combo mrbrnz Australia Wanted to Buy 0 10-10-2007 06:57 PM
TRX 2.5 issues C_J_GO Monster Trucks 0 10-18-2006 03:00 PM
Some issues with the Lst sjlam Monster Trucks 7 11-06-2005 05:50 AM
FTS issues TeamButter Florida Racing 30 02-24-2005 05:01 PM
SEO by vBSEO 3.5.0
