Team Losi JRXS
What would be better, running the rear diff looser or tighter stop the tail comming loose when getting on the throttle? Would it help at all?
A tight rear diff will contribute to a tail happy situation. You only want to tighten it enough so it's not chirping(?) on acceleration. It does make a difference.
Thanks for that losi nut, i will test it next time at the track.
Thanks for everyone's help on the set up, I'll try it this weekend. I have another question, do any of you have a Novak GTB Brushless system on your JRXS that I can see a picture of. I'm not sure were would be the best place for it on the chassis. Thanks in advance.
JrXs - Asphalt Setup (Xavier 2006 Nats)
Hi all
On Craig Xavier's 2006 Nationals setup he mentions 2 0.050" shims under the pivots that are in the high position. Is he using two on each corner of the suspension for a total of 0.100"? So thats four for the front and four for the rear of the front suspension arms right?
Here is part of the thread from June 2006.
Johnny Wishbone
203 Posts Since Feb 2006
Old 06-15-2006, 02:57 PM Default View Public Profile Send a private message to Johnny Wishbone Reply With Quote
Post #11917
Mr Pookyt, I have a question that I just want to get straight in my thinking. I'm looking at Craigs setup sheet, as well as other ones and I just want to make sure I'm understanding this right as I'm reading them. He is running 2 shims under his pivot block and in the high position, so does this mean he is running the same shims under the rear pivot of the front of the car? If it was just under the front this would be considered a "kick" setting rather than a "roll center" setting, is this correct or am I inline for another smack. I just find it confussing when/or if the adjustment is being made at the same point but using 2 different places to indicate it. To me it would make more sense to have all three togeather on the sheet, if what I'm understanding is true. Thanks ahead of time for clearing this up for me. JP or Doug please feel free to jump in on this one as well.
Johnny Wishbone
View Public Profile
Send email to Johnny Wishbone
Find More Posts by Johnny Wishbone
Add Johnny Wishbone to Your Buddy List
POOKYT
POOKYT's Avatar
Jonesboro, AR
5,130 Posts Since Oct 2002
Old 06-15-2006, 04:00 PM Default View Public Profile Send a private message to POOKYT Reply With Quote
Post #11918
Yup!! Yopu got it! He is running 2 .050 shims under the bar and under the small blocks. And yes, it might be different but he would indicate that on the sheet by showing "Anit-Dive" or "Kick" on the front.
On the rear arm to the front thing, I actually broke my BK rear arm Sunday and used my spare regular arm with a BK bracket. I have looked at doing this thing but man its really just too much work and I am too lazy!!! LMAO
Brant
Johnny Wishbone
Post #11917
Johnny Wishbone
View Public Profile
POOKYT
POOKYT's Avatar
Jonesboro, AR
Post #11918
Brant
rinkrat---Yes......two .050 shims for a total of .10 under each corner.
Brant
Brant
What are your thoughts with regards to Craig Xaviers Asphale setup? Particularly the 41R pulley along with the front spool and the 0.100" shimmed roll centers?
What effect is this gonna have on the car?
It sounds like we are keeping the rear roll center LOW and thus keeping the weight transfer towards the back to gain traction.
Thoughts?
Thoughts?
where can i find the/a setup Todd or Matt used for he track at the 2006 IFMAR worlds? the track i run on is very similar but i can't seem to carry as mush speed thought the hair pins as i want to. i have a problem with the front of the car bottoming out under brakin. i using the travel limiters so it would not bottom out but now the shock stroke is very small. im running a brushless mamba 6900 system.
Basically what you need to accomplish is reducing weight transfer to the front or minimize its' effects on the vehicles dynamics. You can do this a few ways. Stiffer front springs, reduced rear droop, heavier front dampning to a lesser extent, and adding anti-dive. If you feel it is only hitting on the outside during the turn you can also raise the roll center to reduce chassis movement and play with sway bars. Most asphalt set-ups call for pretty high roll center settings.
But when all else fails, have you tried the Numan set-up?
Mike Slaughter
Edit for clarity.
And if you want to get your full geek on....
From http://www.racing-car-technology.com.au/wgttransex.htm
And two components of Suspended Weight Transfer:
Geometric Weight Transfer - due to the component of lateral force, applied directly at the Roll Centre (RC). Geometric WT is reacted directly through the suspension linkages, and does not induce body roll.
Elastic Weight Transfer - due to the component of lateral force, applied at the Suspended Mass CG, and does induce body roll. This force is reacted in the springs, anti-roll bars and shocks, and is the only one of the three components of total weight transfer that does induce body roll.
It is clear that low roll centre give little geometric wt and most of the weight transfer goes through the springs (elastic wt), and is therefore delayed by the time it takes for the vehicle to take a set. Conversely, with high roll centre most of the weight transfer precedes the body roll, leaving a smaller amount of weight transfer to go through the springs.
they used the rear motor car but i still wanted to see the setup. i used the numan setup to start with but it was too soft with both front and rear chassis scrapping the ground under braking and acceleration. i when up to 35 front and 17.5 rear springs but i lost turn in and cornering speed around the hairpins. is seems as though i have to tap the brakes to get the car to turn or just slow down more. thats for the info
19t FGR
Hi all
I ran my JrXs for the first time today on asphalt and was wondering how people are getting a sub 6 FGR with a 118t Spur? Some of these motors need a 5-6 FGR and that would correlate to a 43t pinion.
With the 118 spur you can fit pinions in the area of 45ish with no trouble...robinson sells them.
I was wondering if anyone has tried using the new front upper arms from the JRXS Type R on the JRXS Pro? Will it even fit?
