Team Losi JRXS
many thanks for the link i will check it out but personally i dont have that much time to read 100s of pages lol
so is it just mostly the front end bits with the same like the losi XXXS as i got through lets say over the 50 front spindles lmao
also could someone tell me if the Team orion platinum Lipo will fit in the car?
max amp makes a 4000 that will fit,but i have not tried it yet
Thats about the only thing you have not tried in that car!!! LMAO J/K
Brant
Brant
Brant
you talk to Yeti to much
BTW--As soon as I get Yeti's Body painted I will send it with my one-way diff for you to try. If you guys are running rubber tires on carpet then you really should be using the front one-way. Good Luck!
Brant
Mike Haynes Rubber setup Help
Hey Mike I love this setup I got from you on here a while back. The car is balanced perfect, feels great. On a lower bite track what would you think to change for more overall grip without changing the balanced feel I have now? Maybe go from high roll centers to low? Thanks!
I would say to leave the roll centers alone, i never had much luck with low on rubber tire with my car....you could try to run 1 rate softer spring all around (15/10) and see how that goes, or possibly a bit more droop....maybe both.
Thanks Mike, I will give those suggestions a try.
Brant[/QUOTE]
that would be awesome i have run the center oneway and liked it but want to try the oneway up frt
Brant[/QUOTE]
so the big daddy doesnt fit in hows about the smaller brother Lipo the team orion 3200mah (the one thats in the the carbon firbe looking case)
tam
tam
tam
tam
my little aluminum a-arm braces worked pretty good today. i practiced for a few hours today and did some "stress testing" of the front end. nothing broke.
on a side note, i also think i found why my car wasn't handling so hot. i pulled a n00b move and basically hadn't done anything with my shocks since about june of last year . i put the car on my tweak station and it was all out of whack. i drained and re-filed the shocks, no other chassis changes, and the tweak was dead on afterward.
what's even worse is i've experienced the EXACT same thing with my xxx-s after long periods of not running it.
[QUOTE=TAMIYAMANUK]so the big daddy doesnt fit in hows about the smaller brother Lipo the team orion 3200mah (the one thats in the the carbon firbe looking case)
nope theres no way unless you mod the car and the lipo the bulkheads cover the holes to were the wires go so you would have to drill holes for the wires to hook into the batt. from the front to much work for me and im not afraid to use a dremel
if you want to run lipo get the maxx amp 4000 it will fit in the car with no mods, but it does not have a hard case and some tracks will only let you run with cased lipo's like the 4800 and the 3200
Tom
Tom
