Team Losi JRXS
Scuse my ignorance.... what's the JR link???
JR Link ?
Hey Brant, do you have a pic of the JR link that you use. Are you running foam on asphalt or rubber, as I have a real clearance problem running the JR link with rubber tires. Sure like it on carpet though. Thanks, JW.
http://www.jrxs.com/forums/index.php?showtopic=491
Read all about it.
Brant
I hate to admit that after 4,285 posts, I still do not know how to post a pic in here. Any advice ( in normal southern verse please ) on how to do it the easiest way possible and I will see what I can do. Mine is very similar to the link above that I posted from JRXS.com. Take note of how he back cut into the upper front edge of the link so the wheel will not rub at full lock. Hope this helps
Brant
Brant
Brant
Vid of my first run. Orion Element 19t, GTX, worn CS-27s, and 3PK.
Click here to watch First-run-of-my-JRXS
Originally Posted by annie_himself
Host the pics at a place like Putfile.com and post the BB code directly here.
Durn Brother!!!! That car looks like it went through the Big Flood!!!! J/K
Get a 1.5 inch soft bristle paint brush and dust that puppy off!!
Thanks for the help. I will see what I can do on some pics. BTW.......You guys need to come up to Memphis and run with us when you get a chance. Is Bobby C. and Brian C. still running some onroad over there?
Brant
Brant
Originally Posted by Yeti35
Why when you can post pics here just fine. It is not that hard.
Brant
Brant
Brant
And I actually was too close too the "Big Flood" (Katrina & Rita) only 30mins away from N.O. I think Imma like you. lol
So how do ya do it in here?
Brant
Brant
what do the jr arms do and is it worth taking the time to cut it all up
abd is there any where that shows you how to make them
Hey, annie i see you are having a blast with that car. I dont think I ever had the chassis that dirty when I had it. Did you run the batts on top of the rear deck or were they just like that in the photo.
yes the jr links are very worht it as long as you start with the newman set up also. Makes a world of difference it how smooth the car reacts
Tom--try this link bro.
Brant
