Team Losi JRXS
Craig Xavier's ride. Sorry no chassis shot. I forgot to take one.
MF's Last Call! This was MF's last race in the USA before his official retirement after the upcoming World Championships.
Hodge!!!!! Get on the phone and call MF and tell him " Rehab is for quiters!". He can put the realestate stuff on hold cause it ain't going any where!!!! LMAO
Brant
Brant
On the same note, call ole Jack Johnson and get him out to the track!! I would love to see what he can do with these sedan cars!!
Brant
Brant
hope someone (pooky, craig etc) can help, going to give craigs set up a try and i'm confused by one thing
Its says on the front there is no up travel !! Can someone explain this to me.
By that im reading the up travel limiter set screws (which are attached to the roll bar mounts ) are set once the ride height etc is set so that the suspension is fixed ie no travel at all, effectively locking the front shocks !!
Please advise anyone
Andy
Andy
What Craig means is that there is no additional shock uptravel once the chassis hits the ground, meaning that tires do not travel up past the chassis. Understand? If not I'll try to explain it better.
Yup!! Just what Andrew said! Push the chassis flat to the surface, and make sure the wheels cannot be pulled up any further. Hope this helps!!
Go UK and the JRXS!!! You guys hang in there and you will surprise a lot of people!!!
Brant
Brant
Hey Andrew maybe you know, did anyone (regular car) run the front camber mod thing at the reedy / nats, or did they prefer the regular ballcup setup?
Originally Posted by turd ferguson
No Vegas?
cheers thanks for that i understand what is meant now. I'm also assuming that craig was not using the camber link mod ??
Also, on my setup sheet it says rear shock tower height was high...that's a mistake. The rear tower was in the low position. Sorry about that(Thanks Haynes for pointing that out)
Just put some of the final finishing touches on 'er tonight. Now I need to mount and paint the body. I can't wait to get back out to the track. I should have never sold the first JRXS I had in my hands.
Just to get a reference number, what is the weight of some of the cars out there? Even with the fans, my car seems on the light side...
