Team Losi JRXS
Originally Posted by Randy Caster
Hmm, dont know if I'm the best example to ask, I run the stock bumper, cut down a bit...
Brant
Originally Posted by tim fry
I've got one and cant seem to get it to work but I dont think Helger who import it really fully support it I don't know any of their team drivers who run it. So this means it's hard to find a setup.
Do have to admit though its not been the easiest car to car going well. Think that the set ups dont work as well over here as the grip levels both indoors and out are soooooooo different here compared to the States.
Originally Posted by speedfreakUK
There are a few people still running the car in UK. What surface are you running on I've got a couple of pretty decent set ups for Rubber on carpet and minipins on polished floor.
Originally Posted by POOKYT
How long you been gone and are you running on carpet or Asphalt? Hollar!
Brant
Brant
Hi there, i'm from the UK and I run a JRX-s (i know its rare!!) However if you start with the josh Numan set up you can adjust it with slight and small changes to almost any surface over here, if you are running on polished floors though make sure you have no toe in on the rear end and the car will stay stable at speed and braking. For carpet with rubber i'm regular in the top 5 at my club (i race 27 turn everyone else uses 19t) do every thing Josh says apart from the shocks, keep the standard kit springs and 45 wt oil in the front and 35 wt in the rear and you car will be much faster in the corners that you don't need to have the extra speed down the straight!
Hope this helps!!! However if anyone has any good ideas please let me know!!! there is always time for kicking xray butt!
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by wyd
Did you find that running the Numan setup with the stiffer oil and springs keeps the car driving flatter in the corners.
Front:
50wt Oil
15lb Spring
56 Piston
White bladder
2 O-rings above bladder
2mm droop
4 degree caster
1 degree camber
41T spool
.100" shim under high roll center
diff high
middle hole on shock tower
position 5 on camber link - JR Camber link mod, rear tower on the front see:
http://www.rctech.net/forum/showpost...ostcount=10792
and
http://www.rctech.net/forum/showpost...ostcount=10354
Rear:
35wt Oil
12.5lb spring
56 piston
White bladder
3mm droop
1.5 degree camber
.040" shim under low roll center
diff high
2 degree inboard toe-in
hole 2 on shock tower
hole 5 camber link
any ballast weight at rear of car (as close to the diff centre line as poss.)
If I've missed anything, pm or email me.
Is this a general setup or for a particular track?
Oh, and the motor is at the front!
Tech Legend
Originally Posted by CraigX
WYD, I heard a rumor that you have been considering running a JRXS. If this is true, let me know if you need any tips or anything
Rubber tire set up for carpet
Went to Team Losi site and only one set up from 1 1/2 years ago, can someone post a good rubber tire/carpet set up or post a link to one. Gonna go up to Trackside for the stock rubber tire national at the end of April and I normally run foams, so looking for somewhere to start.
Thanks....
Thanks....
page 316 on this thread has a winning setup for Trackside rubber class
Originally Posted by J A M I N
Its a good starting point, I've tried it at two tracks, Ipswich and Southend, both of which are technical twisty tarmac tracks.
what effect does putting the rear shock tower on the front give you?
Thanks I appreciate that. Rumor mill is true. I just can't help myself. I guess I'm Teach JR!!!!!!!!!!!!!!
