Team Losi JRXS
Originally Posted by R/C Anonymous
Trakside- i responded to that post earlier
Cheers Malc TCCFM
Originally Posted by DR.FeelGood
Hge glitch problem with the JRXS. I just got the car two weeks ago, I got the car from someone who already had it built and setup. THe car glitches so bad that I can not even make it a lap. It seems that the SERVO is causing the motor to do all kinds of stupid stuff. Sometimes when I am turning the wheel The motor JERKS hard and then cuts out. I have done the following to try and figure this out. Motor is a EPIC 27 turn. It has the chip on the back of the motor to reduce noise but still nothing. I have changed servos, recivers, radio and the motor twice and its still undrivable. If anyone could offer any ideas that I could try, because this car is about to get a flight out the freakin WINDOW!!!
THanks
CHris
THanks
CHris
THanks
CHris
THanks
CHris
any ideas?
Hope this one helps you Dr Feel Good
Cheers The CanFanMan
if you want the setup its a couple pages back and on JRXS.com if you want the car ill sell it cheap...i got 8 cars right now!!!
any ideas?
Originally Posted by rcracingkid
Do you have a personal transponder on the car? I had my personal mounted next to the reciver and got crazy glitches...couldn't go more then 5 feet from the radio.
DR.Feelgood
Try mounting your reciever on its side instead of flat on the chassis and see if that helps. and try to keep the receiver away from the batteries as well, good luck. try to mount the receiver parallel with the antenna mount as a referance point.
Originally Posted by dawgmeat
Can you hookme with a set-up for south shore 19-turn
Here's my mod setup I used this past weekend if anyone is interested.
Here is my current setup, it worked very well at the Magma race, and is what i typically run at SouthShore.....its dialed in for mod or 19 turn, should be decent in stock also.
Dawgmeat, if you want an older setup with the normal arms i could post that also.
Cheers T CAN MAN
Cheers T CAN MAN
Originally Posted by Trakside Trucke
Is this the same setup as yours Anon, as I looked on page 316 and could not find your set up if not, could you let us have it ahgain please
Cheers T CAN MAN
Cheers T CAN MAN
Probably still good enough to make the A main at the Novak Race or top of the B
mine is for stock rubber carpet(the older carpet not the new CRC Fasttrack stuff) i tried my setup at S&N's trackside(much higher traction carpet then what i usually race) awhile ago and it was fast except in the sweepers(about .7 a lap slower then the fastest rubber tire car there).
THE CAN MAN
