Team Losi JRXS
#9272
Originally Posted by UNSTABLE
Just won the New Zealand North Island champs over the weekend, the car was sweet, super smooth.
If anyone needs a setup for ashphalt with foams, try this:
Ashphalt foam setup
Ashphalt foam setup
Brant
#9273
Thanks Pooky!!
#9274
Iz all yoo man!
Brant
#9275
5thscaleracer=
"thanks,,,That made my day"
Originally Posted by 5thscaleracer
yes it is night and day difference with these TH/BK/PK and with out the TH/BK/PK brackets. It's a good thing BK made a set for his car for others to . It has made the care much more consistent and predictable vs with out them.
Thank you BK for the IDEA PK for supplying us and TH for revising the original design.
#9276
DIRT
You have YGPM
You have YGPM
#9277
How about 3.5mm chassis but have the sections where the bulk heads, suspension arms, servo, posts etc milled out to stock thickness. providing a ridge around the endge of the car as well as sections in the center. My main point is the weak spot from right after the front bumper all the way to the rear bulk head screw and pivot blocks. That hollow space has no support and does flex/crack.
Winky was having problems cracking in that area he has purchased 5 chassis already i have made a thicker chassis using a different epoxy and a 45 deg wet lay which deemed too expensive. only had 2 made at $120 a pop
But if you can make one that specifically thickens that front part of the chassis that would be ideal.
#9279
Brian,
It's nice to see ya back and gabbin'. You must be feeling somewhat better. Lookin' forward to seeing you race again.
Paull
Paull
#9280
Hey guys,
I'm new the the JRXS and would like to know a concensus on battery wiring. What has worked for you and please post pictures.
Thanks,
Eric
Thanks,
Eric
#9282
Originally Posted by DIRT
5thscaleracer=
Drink your Gatoraide and take dem vitamins and get your self back to the track man!!!
Brant
#9284
Originally Posted by EAMotorsports
pooky when you gonna bring that car over and run some carpet?
EA
EA
Brant
