Team Losi JRXS
#8852
Originally Posted by huskerfreak
I think there having issues with the server company did you try .com
Thought maybe it had something to do with the new chassis!
Have any tried Losi setup #3 yet?
#8853
#8854
Originally Posted by Trakside Trucke
Do you guy's remember Isaid I had a rather large tweak when I built my new JRX-S !!!!!!!!!!! well
My car was great on rug, well it was until I decided to re-build it that is, you see, When I first built it there was a massive tweak in the car when I first built it! the left rear shock collar was wound down at least 3mm more than the right rear shock, and the front right shock was wound down 2mm more than the left front so as to balance it out on the tweak station (frustrating or what ) so ran it like that for the first meeting, and was built to stock. The back end was real lose, so I put some 1 degrees rear hub carriers on tuned over the rear wishbone retainer, and front rear wishbone retainers, so as to lower the centre of gravity at the rear and reduced the rear droop from 4 to 3mm and was bang on the money. Then I decided to re-build it so as to get rid of the tweak (not that I was in a hurry when I first built it as im not like that with my builds) I stripped it right back and re-built it checking on a flat plate as I mounted each individual part, but low and behold, come to checking the car on the tweak station, it had the same bloody tweak, I could not believe it. So i took it with me Friday to our club night and showed one of the guys that has been racing for arns, and sussed it in 2 minutes, the rear bulk head set are of different heights by 1.5mm and same with the fronts GGRRRRRRRRRRRRRRR!!!!!!!!!! Anyone else come across this? im gutted now i have to mess about shimming the bulk heads to equal hieghts
Malc TCCFM
Malc TCCFM
#8855
Mine is perfect.
#8856
Malc TCCFM
Malc TCCFM
i would E-mail Losi and see what they have to say or offer i am sure it's a mfg Defect as they can't be off by that much?
#8859
Alu battery tray w/ the new arms?
I've been waiting for the big battery tray for 2 months now and it keeps getting pushed out. On the Horizon Hobbies website, first it was late October, then early November, now late November.
I have this terrible feeling that the big battery tray is joining the new suspension arms in unobtanium land.
I like my JRXS, but I would really like to be able to get some of these key parts in a timely fashion. Is this type of parts delay unusual for Losi, or is this standard operating procedure?
Ira
Ira
#8860
Originally Posted by rayhuang
weliin-I dont think anyone is cutting teeth on the belts. For sure I wouldnt cut any teeth on the grey belt. If you did the white belt-unlike on the Xray 04's or the XXXS's-I dont think youd feel a difference as drivetrain efficiency appears to be excellent already.
I've run the Belts cut for a long time no issues, the great thing is ever other belt cuts perfectly. Still on original belts
JRXS.com is working fine.
.net is gone and may not be back, sorry for the inconvience
#8861
Originally Posted by Greg Sharpe
It's my birthday and I'm spending the morning practicing with my JRXS. There ... I'm done sharing.
its mine to, im 49 today how old are you
TCCFM
#8862
'How many licks does it take to get to the center of a tootsie pop?' Like getting parts from Losi... 'The world may never know.'
-battery tray
-2* rear hubs
-new arms
-complete shock kits
Oh well... Just jokes... don't hurt me!
E.
-battery tray
-2* rear hubs
-new arms
E.
#8863
Are people using the BK Brackets on carpet setups with foams?
#8864
This allows me to use 26mm fronts and I run the brackets on the inside hole at the rear so I can fit 30mm rears.
#8865
If you want to use the aluminum bk brackets you will need to grind the arm so the bracket is recessed into the arm. Then the foams will work. I ground my arm the same thickness as the bracket. This is for 28mm foams in the front in the rear 28mm should work standard.
Paul
