Team Losi JRXS
#7891
Guys take a look at pic 7 on this link http://tqhobbies.com/iic2.htm , there's a pretty good pic of a JRX-S whith the motor behind the batteries, is that a new JRX-S? Is it a production car?
#7892
POOKYT,
Thanks for the advice. I was looking at switching to Numan's setup, however, since the track I run at is extremely tight, I didn't want to run the spool. Would running the setup without a spool dramatically change the handling from good to bad? Thanks again!
#7894
No
No that is a losi I saw Billy Easton driving the same car
#7896
Originally Posted by airbear87123
POOKYT,
Brant
#7897
A question for you guys. When you are talking the length of the shocks. Are you talking about from the top of the shock to the bottom of the rod end. Or by the Losi shock tool or where the screws attach the shock to the mounting holes. Also is it measure fully extended?
thanx in advance
thanx in advance
#7899
Rob,
Understood.
thanks
Understood.
thanks
#7900
o-rings
Hey guys,
Can someone explain about the "2 white o rings" or "2 red losi o-rings" above bladder in Josh Numans set. I dont quite understand do these sit in the shock top cap??? What does this actually do??? and can some one give me a part number for these??
Thanks,
Gareth
Thanks,
Gareth
#7901
Originally Posted by Floss_LUC
Hey guys,
Thanks,
Gareth
Thanks,
Gareth
They assist in re-bounding the shock when compressed. Thats all I know. ,
Different types (white/red O-rings, Red foam spacers) creating different effects.
#7902
Originally Posted by POOKYT
Good Deal!!!! My Dremel tool is threatening to go on strike anyway! LMAO
Here is a classic for you old time JRXS racers!! " The new arms should be out in about 2 weeks" LMAO!!!!!!!!!!!!
Just kidding around. I will order a set of the new arms as soon as they are availible as well.
Brant
Brant
#7903
Originally Posted by losi-xxxs
This will probably sound like a really dumb question...but what are these new arms I am hearing about?
Hope this explains it properly.....
#7904
Hey guys,
Thanks,
Gareth
Thanks,
Gareth
Hope this helps Gareth
Brant
#7905
LRP V7.1 esc
I am thinking of moving to a LRP V7.1 esc from a GM SX-9 which smoked this past week. HAs anyone tried this esc in the JrXs and if so, how did it fit? Did it require any counterweights?
