Team Losi JRXS
#6826
Originally Posted by 2-Bad
Good idea; Roo's are notorious for doing nasty things to lone strangers in the bush…..watchout went they form into a “gaggle”……..
#6828
Don't worry Bill, I'll protect you.....
#6829
Do they have banjo's in Australia???? LMAO
Brant
Brant
#6830
Brant
Brant
You gotta get out of Arkansas and see the world bro...
#6831
Originally Posted by JRX-S Bill
Banjos in Brisbane??? No, just lots of roos...
Brant
#6832
Good drive yesterday "Dirty"..... is it "the car", "the driver", or my moral support, "Young Padawan".........
well it's DEFINATELY NOT the latter!!! In fact I think your so called 'moral support' stopped me from driving better!!!
Oh well, there's always a next time.
#6834
If these guys are 'down under' are we 'up over'???
Will our setups even work in Australia??? Makes no hemispherical sense to me...
#6835
Originally Posted by Evicerator
Here's the setup I ran at the Reedy Race in case anyone is interested...
FRONT SUSPENSION
Toe In/Out - +1 degree
Ride Ht - 5mm
Camber - Neg 1.5 degree
Kick - 0
Caster - 4 degree
Pulley - 41F
Front Drive - Spool
Diff Height - Low
Sway Bar - None
Front Pivot - 0 w/ custom -1 deg inner pivot supports for 1' arm sweep w/ narrower track (1' block can be used w/ standard blocks for similar geometry)
Roll Center - High
# of shims under front blocks - 0
Shock Tower - Low
Center Drive - Spool
Drive Shaft - LCD w/ Bearings
Camber Ball Stud - Short Neck
Shock Position - #1 at Top and in BK bracket
Camber Link Position - inbetween 1 and 2
Hex - Standard
Drive Axle - BK bones
Ackerman - #2 (belcranks moved back 0.150" in top deck)
Bump Steer - 5 0.030" washers on each spindle
Drag Link Location - Above
Droop - 10 mm above ride height
Arm Spacing - 0.040" back from full front
Shock Oil - 40wt TL
Shock Piston - 667
O-rings in Cartridge - 1
Bladder - Tamiya
Above Bladder - nothing
Spring - 15
REAR SUSPENSION
Toe In - 2 degrees
Ride Ht - 5mm
Camber - Neg 1 degree
Shock Position - #2 top and in BK bracket (BK bracket attached at outer hole in arm)
Camber Link Position - #8(Used TC3 rear hub carriers in inside lower hole)
Hub - 0 degree
Hex - Stock TL
Drive Axle - CVD w/ bk bones (bearings)
Camber Ball Stud - short neck
Shock Tower - Low
Diff Height - low
Sway Bar - None
Rear Pivot - 2
Roll Center - high
# of shims under blocks - 0 (no antisquat)
Droop - 9 mm above ride height
Arm Spacing - 0.040" from full back
Shock Oil - 35wt TL
Shock Piston - 667
Bladder - Tamiya black
Above Bladder - Nothing
Spring - 10.5 lb
Misc.
Ran Stratus 3.0 AP and Ride Accord bodies
I'm sure I forgot something...let me know if you have any questions!
FRONT SUSPENSION
Ride Ht - 5mm
Kick - 0
Caster - 4 degree
Pulley - 41F
Front Drive - Spool
Diff Height - Low
Sway Bar - None
Roll Center - High
Shock Tower - Low
Hex - Standard
Shock Oil - 40wt TL
Shock Piston - 667
Bladder - Tamiya
Spring - 15
REAR SUSPENSION
Toe In - 2 degrees
Ride Ht - 5mm
Hub - 0 degree
Hex - Stock TL
Shock Tower - Low
Diff Height - low
Sway Bar - None
Rear Pivot - 2
Roll Center - high
Shock Oil - 35wt TL
Shock Piston - 667
Spring - 10.5 lb
Misc.
It's soooo dialed!!!
Leonard.
#6839
Note to Bill: "Gravity Sucks"
#6840
guys, I'm helping a buddy build his JRXS and was wondering where he can get this bk bracket. I went with him to the hobby shop and the dude behind the counter gave us a blank stare as if we were on crack. LOL Is there a part # for this? Any help would be appreciated.
