Team Losi JRXS
#5821
Originally Posted by J Tronzano
Not just you, me to. I posted the exact problem several pages back but got no input from others. Must be a sparadic issue. But anyway upon checking the blocks from my car i found that one side was actually a 2* block and the other 4. Replaced it and everything fine.
Goof Luck
Goof Luck
#5822
Right side also.
#5823
Dynamite hexes
This is what I did to be able to use the Dynamite aluminum hexes on my car.
1-drilled out the pin holes to 0.067" with a numbered bit. This size is perfect. Pin slides through easily-but with no detectable slop.
2-sanded the backside of the hexes used in front so hole in hex and axle line up.
Its all good now ,
Ray
p.s. thanks Pookyt
Its all good now ,
Ray
p.s. thanks Pookyt
#5825
Originally Posted by HarshGuy
You coming up Thursday/Friday?
And still trying to figure out if we will have any 1/12th scale racing too.
Bill
#5826
Right side also.
Todd Hodge gave me some of the newest 0 degree hubs which have a small "TL" printed above the "0 deg" indicator. These were perfect, but may not be in great distribution yet.
Contact Team Losi for replacements.
Bill
#5827
Originally Posted by SoCalLosiRacer
The one-way that I bought only had one outdrive. No biggy, I'm waiting on an email from losi to see if they'll send me another one. Just something to look out for if you buy yours in a store and can see it as opposed to ordering online.
Drop me a email with your address and I will send it out today.
#5828
What day will you be arriving at SW?
Bill
#5829
Originally Posted by JRX-S Bill
For me, it was the left side. Basically, I got two 1 degree LEFT side rear hubs in my kit marked as "0 deg".
#5830
How are you guys using XXX-S rear hubs? I had a set of 1 degree offset huds for a XXX-S but they are wider than the hubs on my JRXS. Luckily I got my new 0 degree hubs from Todd Hodge today and they work great.
#5831
The rear hubs are the same. The are also the same with the exception that some material has been removed to allow for maximum steering throw.
#5832
DJG24, all the XXX-S hubs work fine. The ones you had that were offset are for foam tires on carpet and mount in the inner holes on the arm. The stock hubs on the JRXS are not offset, mount in the outer holes on the arm and are for asphalt or rubber tires on carpet. Both hubs fit, you just need to pick which one you need for your application.
#5833
Rear Hubs
Todd,
Do you have a part number for the O* rear hubs and when will they be available. I would like to get a spare set.
#5834
With the discussion of the offset vs. standard rear hubs, I just wanted to say that the offset hubs can be used for things other that carpet/foam set ups. I used the offset hubs on my old XXX-S this winter running stock rubber on carpet, and they worked great on the car. The offset hubs free up the rear end of the car, making it more aggressive. Useful in any kind of high traction situation.
#5835
Its all good now ,
Ray
p.s. thanks Pookyt
Its all good now ,
Ray
p.s. thanks Pookyt
Brant
