Team Losi JRXS
#4501
Originally posted by rayhuang
Thanks Rob. Unfortunately in the Main I ran a pack that had been charged for 5 hours too. Maybe only worth a couple seconds-luckily I ran a fresh cut motor !!
The pack I charged for the Main wouldnt fit-I couldnty close the battery door-lol. My only GP3300 pack that wouldnt fit.
It has been said and has become a large topic out here, but the most important thing is to get the slot in the chassis right.
#4502
I just have to post to you all how I choose to wire up my JRX-S. It is nice and neat and make it so ther is little chance of me melting my belt on accident. I took half of a battery bar and bent just about half of the the end out to accept the wire. I only did half so that is was easier to install the batt's. And as you can see I ran the wires around the stand offs so that I could get my iron in the side to solder. Now it does make is a bit more difficult to hold the wire but I always use pliers anyways so it is a no brainer for me. but it is pretty easy. I just wish I could drive the car since I have all this neat wireing done. I was a victim of missing parts. But here you all go. What do ya think?
#4506
Ray, PM me your tele again I lost it!!
KE
#4507
Originally posted by nnick
Hello,
Is it possible for someone that has the Los3018 thrust to provide me the following details?
thickness
total diameter
inner hole diameter
of the plates/washers
Thank you
Nick
Hello,
thickness
total diameter
inner hole diameter
Thank you
Nick
#4509
Todd,
For stock/foam racing-whats the lowest rear toe in youd recommend and how to achieve it?
In other words-0-deg pivot blocks and 1-degree hubs
-or-
2 degre pivot blacks and say 1-degree hubs on backwards.
I am leaning towards less inboard toe in and put it on the hubs. Makes car more aggressive???
-or-
#4510
Shop Owner
Originally posted by Gearhead3
why? need it for your xray? I have had several guys with X-rays come in looking for replacement for the Thrust balls w/race. The Duratrax Trust balls for the Nitro evader seam to work fine, but did not get a chance to try the JRXS balls w/race, but It does look very close in size to the xray......
XRay's are very expensive and I'm looking for an alternative!
If you can measure them it would be nice (the whole xray community will thank you )
Thank you
Nick
#4511
This sucks I just buy the jrxs and a week later my local track closes.
#4512
Some landlords are desperate and some understanding to the needs of a non-for profit club or group looking to rent some space for a track.
Also see if the old woners will sell there carpet and/or scoring system cheap.
YOu can do it-I did.
#4513
What?
This serves no purpose.
#4514
You got it
Thank you
Nick
You got it
Thank you
Nick
#4515
Todd, RBLove, Ray or Anyone
How far out do you have to space the front shocks top and bottom to run the number 1 hole inside on the tower? So that it does not rub.
Thanks,
Thanks,
