Team Losi JRXS
#1787
Juan-The SK2 has more steering than the Alfa.
Cole Trickle- The car uses all the same bearings as the XXX-S in the spindles, rear hubs, and outdrives. It also uses the 5mmx8mm bearings in the diff. The center shaft uses two 4mmx8mm bearings.
stumper-Ouch!!
J.Filipow-Yea...there is this really cool guy I know who designed it for me....I can hook you up....lmk!
stumper-Ouch!!
#1788
What color yellow and blue did u use on that body? Looks nice.
Does the car hanle better with rubber tires or foams?
When you add weight to the car where do u put it to make it balanced?
#1789
Trader Rating: 32 (100%+)
Todd....Whats the relase date on the new car? That new Skoda body is Sharp....Nice job guys.
#1790
Re: Release Date
Originally posted by T. Hodge
Hey guys,
I just rec'd word that it is going to be late February when the car hits the streets.
Hey guys,
#1791
Re: Re: Release Date
Originally posted by EricF
UMMMM, KEVIN, LOOK UP!!
#1794
Regional Moderator
Since we're on the subject of bodies...
Does anybody plan on usinig the fifth body post? I've never thought that I was going fast enough for it to really help anything. But I do plan on using this car for mod. class, so I was wondering should I actually consider using it now.
#1795
IF i race mod I will use that post, but for stock I won't, unless i see that the body is flexing, then i will use it in stock. But it should not flex when using a stock motor.
#1796
A few weeks ago, Matt had the 5th post on his JRX-S acting as a platform under the hood. There is no hole in the body and no clip to fasten on top. Just provides upward support without the hassle of fastening another clip.
For about six months, I have been running a standup foam pad (AE battery cell spacer glued in place) on the top of my XXX-S's tunnel that extends to the bottom side of the hood. The two apparent benefits of the body not flexing just in front of the windshield are...1) far less cracking at the tops of the front wheel wells; and, 2) car seems to be less affected by those ugly first turn multi-car pileups. Therefore, I will run the 5th body post on the new car the same way Matt has his now...regardless of what motor I run.
#1797
I added a fifth body post to my TC4 using one fo the holes in the gearbox for the NTC3. I mainly did this to help save the body from cracking the wheelwells. I went thtough the body and use a clip becuase I noticed that when you push in on the front of the body, it tries to push the hood up just below the windshield.
#1798
Thanks.
#1800
yeah using a 5th somtimes even a sixth body post for me is common practice in drag racing. But i would think that stock would not be fast enough. But mabe im wrong.
